Question about Dryers
Why did the red wire that comes high limit switch to heating element get hot & burned off . I had just replaced thermal fuse yesterday & now this happens .
    Sergeant:
  • 181 Answers
I would say the slide on terminal was loose and arced causing a high current situation that caused the wire to overheat. This is a guess without seeing the wiring.
Posted on Jan 04, 2015
SOURCE:
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
MY WHIRLPOOL DRYER WONT DRY NO HOT OR WARM AIR
There are usually two reasons for no heat.
1. The element is burned out.
2. The high limit switch or thermal fuse has opened.
This is assuming it is a electric dryer.
If it is gas it is probably an ignitor failure.
To check the thermal fuse unplug the dryer remove back cover look for a small usually plastic looking piece with two wires attached
remove wires and check for continuity between teminals
if open replace.
if there is continuity chances are the element has failed
these can be more difficult to replace depending on model.
recommend contacting a service proffessional.
there is usually a reason for the thermal fuse to fail ( ie high heat)
check venting for obstructions and lint filter.
hope this helps.
Dec 02, 2013 | Dryers
DLE330RAW amana dryer running too hot
The control thermostat on the blower housing is the one you need to change if it is getting too hot. It is taking too long to shut off the element. The only other thing it could be is a blocked vent making it overheat. The fuse is set for 350f the limit on the element is a 250 f one. I suspect the 250 f limit on the element is doing the drying not the control stat. Hence you getting overheat but not hot enough to blow the fuse.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2013 | Amana DLE330RAW Electric Dryer
Put new thermal limiting switch, thermal fuse and heating element in my whirlpool estate elec. dryer. it will not get hot still is there something i,m missing?
their are several possibilities
1) check breaker and or fuse to be supplying 240 volts to the dryer,even though the breaker seems to be on a internal burned out breaker will appear to be set but 240 vac not at dryer
2) check were the cord connects to back of dryer that one on the legs hasnt burnt and only 120 vac to dryer instead or required 240 vac
3)depending on your model i dont know if you have a timer or computer control but it isn't sending power to the element
4) the motor switch could be defective, all dryers are required by law to have a built in safety that assures the dryer will not heat when it isn't running to do that all dryers have a switch built into the motor that will only send power to the element once its running
5) in addation to the high limit t-stat and thermal fuse all dryers (depending on model) have a cycling t-stat or thermistor that controls the normal operating temp (the high limit and thermal fuse only come in to play when a dryer overheats) that could be defective
Jul 22, 2011 | Whirlpool Washing Machines
Wont get hot ,put a new heating element in still wont get hot ;
try replaceing high limit or thermal fuse. Thermal fuse can be tested with a volt meter useing continuity be sure to unplug machine and pull atleast 1 wire off thermal fuse.
May 01, 2011 | Kenmore Dryers
Roper dryer does not heat . replaced heating element and thermal fuse. what's wrong
No heat at all is usually the thermal fuse, the high limit thermostat, the heating element or you have a bad breaker at the box and are running on 1/2 phase (or 110 only).
With the power OFF and the dryer unplugged. Use and ohms meter (borrow one or pick up a cheap one for around $10-$15) & check the high limit thermostat (right hand side at the base of the housing for the heating element), take the wires off both terminals and check for continuity between the terminal (set the meter of ohms place the black lead on one terminal of the thermostat & the red lead on the other terminal, doesn't matter which, the needle should move, if it doesn't, replace the thermostat).
You can check all the thermostats, fuses, door switch & the heating element this way.
Feb 12, 2011 | Roper Dryers
Dryer spinning but not drying!
if it runs with the door open the door switch could be defective,otherwise check your heating element high limit/cycling thermostat switch,then the thermal fuse on the side of the vent housing.and also check the power input for 240 volts a.c. if its an electrically heated element,if inside the terminal strip any terminals burn or break off the element can't heat/if its a gas dryer,check the thermal fuse,the high limit thermostat,the radiant sensor on the burner tube or the gas boost and secondary coils on the gas inlet valve,they get weak or open and close off the gas supply
May 13, 2010 | Whirlpool LER4634J Electric Dryer
For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Whirlpool LER7646E Dryer
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
