Las fotos de dia salen veladas
SOURCE: LAS IMAGENES SALEN NEGRAS
You have screen problem on back lights. Please get it replace at dealer
Regards
SOURCE: NECESITO EL DRIVERS O CONTRALADOR
Hi, Kindly get it downloaded here:
www.nodevice.com/driver/.../Samsung/Digital_Cameras.html
www.givemefile.net > ... > Camera & Foto > Digital camera
Regards, Jay
SOURCE: Cuando tiro una foto de dia la imagen sale muy
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
SOURCE: Hola, las fotos con la
¿En que modo estas sacando las fotos?´¿Est? en autom?tico? Podr?a ser que el sensor de luz est? dejando pasar demasiada luz y quema las fotos. Puedes intentar de resetear la configuracion a la de f?brica, esto generalmente est? disponible a trav?s del men?. Si esto no lo soluciona probablemente haya un problema con la camara.
