? 4:39
https://www.youtube.com/watch?v=Oe0BJmXhh7M
Dec 20, 2012 - Uploaded by PartSelect
Remember, parts are specific to your model and the ones shown t. ... Range/Stove/Oven Repair - Replacing ...
? 9:20
https://www.youtube.com/watch?v=sHWRRMrIpfU
Jan 29, 2012 - Uploaded by Tomahawk DIY
If I order on ebay for ge gas range oven ignitor do they as formodel #? .... removed the entire gas tube with ...
? 11:16
https://www.youtube.com/watch?v=BQNs4gHlT_A
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Fix a GE Wall Oven which has some of the following dilemmas:Not heating By ... GE, Hotpoint & RCA ..
Most likely the oven igniter has failed. Turn the unit to bake, the gas should come on within 35 to 60 seconds (at the most). If not, replace the bake igniter. DO NOT TOUCH THE BLACK PORTION OF THE IGNITER with your fingers, this is true for old and new.
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both. if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both. if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time GENE
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both. if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time Gene...OldTech2332
First off, decide which you have, a pilot lite or an igniter coil. In electronic controlled units, when the oven won't light, as long as there's gas available, 98% of the time the igniter is bad, even though the old one may glow and seem to be very bright, it could have a small hairline crack in the ceramic, which would not allow the proper amount of electrical current to travel to the gas oven safety valve, which would then make it open and release the gas. A new igniter works almost every time.
