SOURCE: Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
SOURCE: hoover nextra hnf2137 wont drain
Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning Hope this helps
SOURCE: The start delay flashes in
Program error due to maybe a delay in the fill and drain cycle, Get the inlet and outlet valves cleaned( drain should be quick)
Now if during the cycle the program is cutting off voltage to the motor, then the control board can be faulty.
Check if the drive is having connection fault to stop the motor voltage.
SOURCE: Water not heating & no heat when drying.
It appears your heater has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
