Question about Toshiba 65H80 65" Rear Projection Television
Component Video Only
My 65H80TV will not allow any of the non component inputs to work.
The 2 components inputs work fine. When I try use any other other inputs the screen goes to wavey green or pink patterns and I cant read the input menu until I go back to a component input.
Once and a while the non component inputs will work fine, but very seldom.
It looks like some sort of sync problem.
Thanks for any help you can provide.
  • 1 more comment
  • draftpicks Nov 12, 2007
    No, I disagree, sometimes it does work fine.
    If it was short, it would never work.
    I definitely think this is an internal problem.
  • draftpicks Nov 13, 2007
    thank you premtech, I will try that and post the results.
  • 934 Answers
Not a lot of infor here without some trace testing and injecting a signal to find out where and how it's lost, but try this: Set it up on a non-component input and power the unit. Locate SR41 a small relay on the signal board and tap lightly around it with the back side of an insulated screw driver. Have someone watching the picture. If the
Posted on Nov 13, 2007
  • William Rayburn
    William Rayburn Nov 13, 2007
    If the picture corrects then replace the relay, Toshiba p/n# 23146558
  • 306 Answers
Sounds like theres a short in side with those connections, (possibly bad installation when it was assembled, may need repaired.
Posted on Nov 12, 2007
  • cory casper
    cory casper Nov 12, 2007
    you try wiggeling the connections with it plugged in and see if the screen changes?
  • cory casper
    cory casper Nov 13, 2007
    either way the connectors will probably need reseated and soldered, if your farmilar with that it will save you a few bucks. or you can have a proffessional do it.
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
No picture on tv
This unit upconverts all video inputs to component output, so connect all your devices to your denon audio and video inputs and component video out of the denon to the tv component in and all should work fine
Feb 21, 2009 | Denon AVR-886 Receiver
Black and White Video input
Check your plug that plug into computer, one of the legs has bend.
Jan 13, 2009 | Samsung T220HD LCD Monitor
"No Sync Signal" on both component inputs
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2017 | Hitachi 50V720 Television
Component video inputs 1 and 2 look very fuzzy, but DVD component doesn't, 720P
Hello, I am sorry for your issue. The audio inputs should not matter. It sounds like those inputs do have a problem. Please contact Onkyo at 800-2291687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo TX-SR304 Receiver
X-box 360
You can get a video selector which allows you to connect a number of hd sources to one component selection. Many Tv's of this type only allow you to use component one in HD the other component inputs will only synch with a non HD source like a 480p or 480i output
Apr 30, 2008 | Protron PLTV-32 Television
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Toshiba 65H80 65" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
