I have a fridgidair #FGHB2869LP4 and it had been collecting ice in the back and i had a repair man come today. He wasn't sure how to fix this model and didn't want to get into it before reading up. All he did while here was take the drawers out and chip the ice out. We dumped the ice out of the ice maker and put everything back. Now, we were getting water and ice and it just quit. Completely quit and no lights no sound no nothing. What the heck happened and is there a reset button or anything? Any ideas and this can't be a coincidence can it? I was beside him the WHOLE time and I know that all he did is what I said. He did not even pull the unit out of it's spot.
Hi Cindy, just make sure that it is plugged into the electricity outlet firmly. Sometimes a small nudge can be enough to dislodge a power plug.
Testimonial: "It came on but still won't work. Only the panel board came on. It says SY and CF as the error code but I don't know what it means?"
Unfortunately it means there is a communication error between the main controller and the user interface board. There are many reasons for this. You should call an authorised service centre for a repairer familiar with this model.
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module. Should also replace ice maker thermostat when changing the module. Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs. If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
SOURCE: Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
SOURCE: Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
SOURCE: Water/Ice Dispenser Does Not Consistently Work
My ice and water in the door no longer work on my side by side Sub Zero. I can only get the ice from bulk ice inside the fridge.
Thanks,
Sandra
