Question about Samsung Computers & Internet
I have a Samsung Syncmaster 2053bw. Screen
I have a Samsung Syncmaster 2053bw. Screen remains black other than a box in the upper left corner that keeps changing from analog to digital. How do I get it to be on analog setting for good so i can actually use the monitor?
  • 34 Answers
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
Posted on Oct 22, 2009
  • 1 more comment
  • David P Oct 23, 2009
    This is how it went for me..I have a Samsung SYNCMASTER 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
    HOW TO OPEN A SYNCMASTER 2053BW
    NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.
    Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too.
    I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
  • Max Schutte Jun 21, 2013
    Thanks for the guide! I got my screen working again by replacing the caps. I just found that my 4 plugs were other way round, photo attached. The second photo has the fixed screen on the right (they seem dark because of the camera flash).
I have Samsung syncmaster 943N and have problem with vertical line in left corner of the screen??
You need to contact Samsung Customer Support toll-free at 1-800-726-7864, or visit www.samsung.com/us/support/ for Live Chat, e-mail, and Twitter support options.
Jun 25, 2012 | Samsung SyncMaster 943N/943NX
Monitor SyncMaster T200 has no image, but LED is blinking. What to do?
That model uses the same power supply board as the Samsung Syncmaster 2053BW and here is a link to a repair guide for that model that should get you going on the right track.
http://www.ccl-la.com/blog/index.php/samsung-syncmaster-2053bw/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 15, 2012 | Computers & Internet
Theres a black box in the upper left corner. Tried turning PIP off and nothing
Could be a closed captioning on. Have run into this several times where its just a blank black box sitting on the screen. That would be the first thing I suggest trying :)
Dec 13, 2009 | Samsung LN55B650 55 in. LCD HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Syncmaster 710 mp picture in picture
Do you have the remote with it? It is the PIP button. When I press that button, I get the small TV picture in the upper right hand corner of the screen.
Jun 24, 2008 | Samsung SyncMaster 710MP 17 in. LCD...
Computers & Internet Logo
4,310 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
