Internet for diagram
Coming off the switch are a green and yellow wire and a black and white wire they run to the door connector then change to solid green and solid black. The window switch changes the current flow to go up or down. To test window motor remove inter door panel, remove moisture cover find motor plug and unhook use jumper wires to test change from pos. to neg. on both wires to check for proper motor function. if motor works both ways replace right side window switch.
