Question about JVC GRD-350US Mini DV Digital Camcorder
Recording We have a JVC GRD 350US Mini DV Digital Camcorder. We have it plugged in trying to record. The camcorder says it is recording but upon playback there is nothing on the screen.
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
  • 170 Answers
SOURCE: Horizontal Streaks accross my lcd during record and playback
Are you trying to shoot from a TV or computer monitor? If so, check the frame rate--30frames per sec (fps) or 15fps. If it is on 30fps, changing to 15fps should solve the problem.
Posted on Feb 06, 2009
SOURCE: Samsung VP-D31 Mini DV Digital Camcorder recording black screen
I have a brand new VP-D31. It still has the protector on the screen. I acquired this (legally!) but it has no charger,cables, battery or any etcs. I got it from the Police Auctions and was too ignorant to understand what I was getting. The item was obviously stolen from a store shelf - hence no bits. How about you buy it from me?
Posted on Feb 12, 2009
  • 148 Answers
SOURCE: Blue bars during playback
Your heads are dirty , clean with a cleaning tape.
Posted on May 12, 2009
SOURCE: How to use an SD card to record on a JVC GR-D370 mini DV?
Download PC Inspector File Recovery.Thank
Posted on May 22, 2009
SOURCE: recording playback has lines through it.
What is the video head and how easy is it to change?
Posted on Jul 15, 2010
0 characters
1 Points
Recording problems
Needs your head cleaning badly (no the camera heads) that will sort you out my friend.
May 26, 2010 | JVC GR-D73E Mini DV Digital Camcorder
Camera worked great until last month!
OK, it is known problem of CCD Imager chip failure in JVC GR-D33 camcorder and ccd imager will be replaced to get live view for recording, lens cap message will disappear as well.
JVC will repair your camcorder free of cost for same problem, click JVC CCD Imager Support for details.
Sep 18, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Recording from the Mini DV to VHS Tape
Mini dv is a digital recording and VHS is analogue so they are incompatible. Does your camera have an analogue output? That is a lead that ends with something like RCA plugs or a Scart plug. Then you can feed the signal into a VHS recorder.
Aug 23, 2008 | Canon ZR45MC Mini DV Digital Camcorder
Lens cap ON sign , no pic on viewfinder when recording
Sent item back to JVC, repaired FOC by extending guarantee
excellent service!!
Jul 17, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
Problems recording onto memory card with JVC GR-D70
DUDE u can only take some stills in the memory mode. no vedio recording is available in memory mode. Thats not a problem DUDE. i got the same model.
mail me
Dec 28, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Do i need a new cam???
You cannot tell if the switch for the eject is broken on the printed circuit boar, or the switch knob may only be internally broke unless you take the camcorder apart. I have seen just the knob break off inside and this know is only a few bucks + the labor, and thats what ia going to cost the most.
Jan 05, 2007 | JVC GRD-350US Mini DV Digital Camcorder
JVC GRD-350US Mini DV Digital Camcorder Logo
16 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
