No. I can't see any network at all. And I have other tabs hooked up to the same network so I know that the network is working.No. I can't see any network at all. And I have other tabs hooked up to the same network so I know that the network is working.
Is the network being transmitted? Have you set up the wifi to hide its name! If so you will have to connect manually!Is the network being transmitted? Have you set up the wifi to hide its name! If so you will have to connect manually!
While it is possible your tablet has a software glitch it is equally possible the electronic circuitry that receives the wifi signal is broken.
If you are certain your internet router is producing a strong wireless signal it will be time to take your tablet in for service/repair or return it to the supplier if it is under warranty.
You have an issue with your network. have you changed the orientation of your transmitter? Is it as high as possible for best signal strength? The wi fi chip/ circuit in pad could also have gone south. Happens.
If it is your WiFi, unplug everything involved with it for 30 seconds and then plug it all back in.
Make sure wifi is turned on.
Make sure that you are trying to connect to a WiFi signal that you know you can connect to. Not all WiFi signals are ones we can connect to with our tablets, phones, and computers. Try connecting to another signal, or try having another device connect to the one you can't connect to to see if it is a device trouble, or an individual WiFi signal issue.
Probably location from Wifi router. I know some of the areas of my older home don't receive a good signal. Check your wifi bars and see if this is a problem due to only one green bar showing as a connection. Rich
You likely have a setting to turn on WiFi. This option is to save your battery, as WiFi drains your battery if it is on continuously. If it is turned off, you will never receive a WiFi signal.
FIRST OF ALL TRY CONNECTING TO A PUBLIC WIFI LIKE A LOCAL LIBRARY. IF IT WORKS THEN CALL YOUR LOCAL INTERNET PROVIDER AND HAVE THEN WALK YOU THRU CONNECTING IT. IT IS A FREE TO DO SO. BUT ALWAYS ASK. GOOD LUCK.
You can try forgetting your network and then joining it again by going to settings, WiFi, the network you are on, then "forget this network", then find it again and join it. If that doesn't work, then you could reset all your network settings by going to your settings, general, reset, then press "Reset Network Settings".
Just to confirm, is WiFi on at the top of your WiFi settings page?
