First off, try changeing from tone dial to pulse dial and try calling out. If that does'nt work, touch bad is probly bad. As far as the speaker phone it does not work off battery's it works from the main base which is powered from the A/C. And for the battery life, when you have a cordless phone you have to build the life to the battery, what I mean is : first time you charge it for 12-14 hours, after that use the phone and do not put it back into cradle, the battery will hold a charge for 8 hrs, if you use it for 30 mins and put back on cradle untill next use, use another 30 min and continue doing this the battery will build its life to 30 min and always die after 30 min, try to get into leaveing off cradle all day and charge while you sleep and keep off cradle all day.
hey hi there battery wont charg does it looks like swell its mean you need to buy new battery or if the battery is still flat then try to boost the battery power booster it will give life to the battery if you can find the battery booster near to you :)
Hi,when a phone does not come on, it is either the battery of the phone is dead, might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored back the phone memory. will need to be flashed.
Hi, when a phone won't turn on or blinks red light, it 's either the battery cell if too weak to power up the phone all application you downloaded on the phone has VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life. You can use the link below to know about how to flash the phone.
if you have had your bluetooth on or have been listening to music for a long time that can drain the battery very quickly . the other problem could be if you are not lettting it die of totally then charging it the battery remembers so when you do charge it the battery dont last long . try turning your bluetooth off or just lettin your battery die off totally then charge it fully
dont upsate friend, i have one solution for u. but i cant say surely to work it. Remove your old batteries and try to insert any usable battery of another same mobile friend and try to check. i think that is battry problem. Or If that not done so go to any nearest Mobile Repair shop.
