Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Screen tuens blue them tv turns off
I have a sony kp-51ws510 read projection tv. its about 3 years old. when i turn it on the screen comes on normal for about 5 seconds, then fades out to blue. when this happens i lose sound and the tv turns off. then i get 8 blinks from the standby light in the front. i took the back off the tv and when i turn it on the red and grren bulbs turn off and all that is on is the blue before it shuts down. what do u suggest?
  • Lia Lester Nov 22, 2007
    my sony kp 51hw40 does the same exact thing.If i keep turning it back on it will stay on eventually but the colors are not lined up.
  • 21 Answers
NOT GOOD NEWS... IT SOUNDS LIKE YOUR BLUE CRT IS SHORTED. THE ORIGINAL PART IS N.L.A.(NO LONGER AVAILABLE) THEY DO MAKE A GENERIC REPLACEMENT, BUT I DON'T THINK THEY ARE AS GOOD AS O.E.M.
YOU CAN TAKE OFF FRONT OF T.V. AND ADJUST THE SCREEN DOWN ON THE FOCUS BLOCK. IT IS THE BLACK BOX WITH 6 ADJ. ON IT 3 ARE FOCUS. 3 ARE SCREEN . TURN THE BLUE ALL THE WAY DOWN , THEN WITH THE BACK OF A PLASTIC OR RUBBER SCREWDRIVER HANDEL YOU CAN TAP ON THE NECK OF THE CRT, NOT TO HARD. SOME TIMES YOU CAN CLEAR THE SHORT OUT OF THE CTR. IF THIS WORKS LET THE SET WARM UP FOR 10-20 MIN. THEN TURN THE COLOR ALL THE WAR OFF, THEN SET THE BLUE LEVER UNTIL YOU HAVE A GOOD BLACK AND WHITE PICTURE. BE CAREFUL NOT TO TURN IT UP YOU CAN DAMAGE THE CTR IF THE LEVEL IS TO HIGH. ERROR 8 IS A.K.B. ERROR THAT MEANS THE CRT'S ARE DRAWING TO MUCH CURRENT.
DON...
Posted on Feb 02, 2008
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 flickering&screen turning green????
Sounds like your focus block is going bad or out of adjustment. It could also be a bad picture tube.
Jul 05, 2009 | Sony KP-51WS510 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Kp-51ws510 picture issues
Bob, remove the front speaker panel and you will see a small access panel remove that also and you will see a small block with 6 dials on it. three on top and three on the bottom. Look closely at the dials and you will see focus for 3 of the dials and Screen for the other 3. The dials marked screen control the drive amount for each tube and are laid out like the tubes green dial in the middle and blue dial on the same side as the blue tube. try turning the blue tube down a little. If that deosnt help you will no doubt need a new blue tube, which is a fairly common problem with that model Sony. If you require more assistance please let me know.
Aug 08, 2008 | Sony KP-51WS510 51" Rear Projection...
Resale value of sony kp-51ws510
Most repair people and shops will sell a used 51" wide screen sony that has a good picture and cabinet for between 325.00 and 500.00 Hope this didn't offend you, but that's all you can get when a new one at sam's club is 699.00 Russmann.
Jun 24, 2008 | Sony KP-51WS510 51" Rear Projection...
Screen is too blue
You will have to take the front cover off, usually 3-6 screws holding from the back, when it does come off there will be wires to the control panel attached still. you will also have another panel to undo. after that there will be a block with 3 focus controls and 3 screen controls marked b g and r for the three colors. The blue screen control is the one you are looking for, be very careful the slightesr turn has huge response including shuting the tv off when you turn it the wrong direction to far
May 06, 2008 | Sony KP-51WS510 51" Rear Projection...
Blue spot
the model number KP-51WS510 deosnt use a bulb or lamp. and touching the face of the lamp will not cause color problems in the picture. if your tv is an LCD projection then i would suspect the optical engine as the culprit. to check when you turn the tv off do you still see the blue distortion? if so then you have a bad optical engine.......as long as it is an LCD projection.
Apr 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-51ws510 51" rear
The picture tubes are on there way out. turning down the screen control inside the tv sometimes gets a little more time out of it
Feb 16, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
