Question about Kole audio Q1-3000D Car Audio Amplifier
Kole Q1-3000D Power Supply caps Keep blowin
I keep blowin the same 2200 uf 80v. power supply Caps, (same 2 out of 5)
I unhook everything before it does more damage.
I replaced the blown 2 with the same rating, 100v this time, it playes fine until it basses hard for a few then blows them again.
what should I look for next? there are no visible signs of other parts damaged.
  • 3 more comments
  • Michael Sanson
    Michael Sanson Nov 12, 2007
    4 gauze , wired on hot and ground, extra battery with isolator in the setup as well,, I just tryed to power it back up and 2 mosfets in the power supply section blew. no visible shorts, board is clean, amp was working fine until when the capacitors blew.
  • Michael Sanson
    everything is wired properly, I have to use another amp til this one is fixed
  • Michael Sanson
    how do I get a 0 or 2 gauze wire in the 4 gauze terminal on the amp?
  • Michael Sanson
    I already have one, the amp has its seperate Optima Blue top battery, ditribution block, and wired correctly.
  • singhna Nov 07, 2008
    Problem Solver:
  • 5 Answers
Sup! i had 3 qx1 3000 amps in my life and they hit hard my subs were down to 1 ohms and never had any problem with the amps and i istalled them myself i no what your prob is like i had with my first kole 3000 i installed i had a 4 g from my battery and i was poping 200 amp fueses i had to upgrade to a 0 gage from battery to the block then 1 4 gage to the kole 3000 and ground 4 gage wow! no more problems never poped a fues again ohhh!! and never put a 0 gage direct in the amp and ground you will fry the amp on a kole 3000 koles are not ment 4 o gage only high end amps are like sundown audio atomics amps ect... good luck!
Posted on May 27, 2008
  • 306 Answers
You need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
Posted on Nov 12, 2007
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Bad capcitors in power supply. Look next to mosfets mounted to heat sink. Will be a 1000uf or 2200 uf caps bad.
Nov 19, 2011 | Televison & Video
Sanyo tv keeps turning itself off any ideas?
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
hope it will help you. -monchi
Oct 17, 2011 | Sanyo Televison & Video
I have my computer hooked up to my proscan 26LB30Q. The power will come on, but it only stays on for about 30 seconds. What do should I do to make it stay powered on?
How are you interfacing your computer to the tv? HDMI? RGB video cable?? Some tv's especially Vizio's will automatically turn off if it doesn't sense a video signal on the RGB input after about 30 seconds. Make sure your computer is putting out a video signal.
Sep 24, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
Green flashing light (like everyone else it seems) a year ago it was still under warranty and Best Buy replaced the DM board (with original caps I assume). I have been researching this and everything I...
yes they dont always puff up on top. But check the ones on the power board there are two 2200 uf, two 3300uf, and foue 1000UF caps that are known to fail and can cause the blinking led also.
Aug 05, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My Sharp LC-46D62U, power light and OPC light flashes twice, stops flaskes twice, stops and so on. I have read it is the power supply. Can i replace this myself?
Fault protection mode.... More than likely you have blown Uf Caps on the PSB-Power supply board. Recap with new Uf caps. A few bucks, solder and a soldering iron.
Jun 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My union color television is dead only power red light is on.
Swollen, Bulged, Bad Capacitor The main cause of this power up problem are bad capacitors on your power if the capacitor is bad
What you need for the opening of the television is Screw driver, Soldering iron(40watts+), Desoldering braid, Soldering wire, and capacitors.
Now lets talk about the specs, capacitors hold 3 important value:
1. The capacitance measured in uF(micro farads) (ex. 2200uF), 2. Voltage (ex. 10v), 3. Temperature (ex. 105°C)
Important Notes:
Flat panel Television power supply capacitors has 10v installed on the board and it is attached to a 12v bus which is causing to bulged.
Look at the bad capacitor and get the right information from it, remember uF, voltage and temperature. Mine, I only change 2 capacitors. It needed two 2200 uF, when I first saw my power supply it was really easy to spot the bad caps. Some Samsung LCD owners did went ahead replace all the capacitors on the power supply to make sure. Now if you’re like me, an inexperience solder, I would not recommend changing all the capacitors because to me it was time consuming for a noob(newbie) like me ^_^.
Few things to take note, always make sure you have the right polarity. Negative part is where the colored stripe on the capacitor.
But if otherwise, the power supply board is bad, you can try websites, to buy a refurbish power supply board for the replacement.
Hope this helpout...
Aug 08, 2010 | Televison & Video
Power light and OPC light flash once then the power light flashes twice...Repeats
Jun 30, 2010 | Sharp LC-52D64U 52 in. LCD HDTV
My lcd samsung doesn't comeon when I turned it on. It clicks for about 5 minutes.
Replace the bubbled caps in the power supply. They are rated at 2200 uf 10 vdc or so. Replace with a higher voltage and you'll be good. I've up to 5 caps bubble up.
Dec 15, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Kole audio Q1-3000D Car Audio Amplifier Logo
736 people viewed this question
Top Kole audio Car Audio & Video Experts
David Burbee
David Burbee
Hashim Khan
Hashim Khan
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
