Dear
You can follow the link. Yes you do have to install 2 carts. to work the printer. However from printer setting you may disable color print.
Note Ink cart head gets clogged when not used prolonged time.
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover. 2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle. 3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta. 4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole. 5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel. 6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
switch on you printer on then open the front cover then the cartridge will be aligned in the center remove the cartridge and take the new cartridge from the box keep the cartridge up right remove the sticker from the cartridge and insert them to the cartridge holder
Replacing the Print Cartridge 1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover. 2 Remove the old print cartridge containing the used ribbon and dispose of it. 3 Remove the plastic stopper from the new print cartridge. Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them. 4 Turn the black spool on the right clockwise to tighten the ribbon as shown. 5 Install the new print cartridge by inserting the recessed first, and then placing the cartridge into its four holders. 6 Press down on both sides of the top cover to close it securely. 7 Close the front cover. Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada). Vertical Black Lines When Receiving The sender's scanner may be dirty. Ask the sender to make a copy to see if the problem is with the sending machine. Try receiving from another fax machine. If the problem continues, call Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada). You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF). Installation instructions will be included. If you handle the print cartridge (frame) carefully, you can reuse it until it breaks.
1) First You keep the printer power on. Open the printer cover - you will find the cartridges holder will come in proper place (the position varies printer to printer) so that you can easily remove the old cartridge.
2) Press gently the upper front portion of the cartridge you want to remove out of the printer holder - you will find it will be unlocked - just remove the cartridge carefully. (in some printer there is a cover on top of the cartridge holder which you can open to perform the step 2.
3) Unpack the new cartridge.
4) Don't forget to remove the plastic tape from the cartridge head (Ex.in HP, Lexmark cartridges etc).
5) Look the printer holder and look to the cartridge - you can easily decide the position of the cartridge in the holder.
6) Gently and carefully put the cartridge in the holder - press the upper portion of the cartridge from front side - the cartridge will be locked autometically in the holder.
7) Put the printer cover in proper place.
8) Print Now - it will print test page first. Now print as usual.
I hope the solution is helpful to you. Thanks for using fixya.com.
This is error is common after a cartridge is refilled, in most cases it's because of "bad refill" and we can also say "dead cartridge". If possible, Please try the cartridge on another printer or try your printer with another cartridge. (i hope you know what tri color mieans = the color cartridge). Make sure the cartridge is not overflowing or leaking. Clean if possible, and never touch the print head, if you ever did so there's no way to make it work again. Hope this helps.
Good luck
Thanks for using FixYa.
so you removed, but could not insert? ok. google for your printer model on how to insert back. Dont touch the heads on the cartride. try this video link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01370857&lc=en&dlc=en&cc=us&product=3418705
Hello my friend, regarding on your problem in installing your cartridge you can see it inside in your printer. Open the printer cover then wait for the cartridge holder to stop swinging and stay in the middle then pull out the two platic attach to the cartridge holder. The plastic u pull out are the ink cartridge and then insert new ink cartridge then insert it again in the cartridge holder the close the printer cover and then you can print and used the printer. Don't forget to turn on first your printer before removing the cartridge.
