Question about Motorola Mobility RAZR V3
Motorola razor not charging..after 1 mth of use
My motorola razor all of a sudden is not charging. i've tried turning the phn off and let charge for more than 56 hrs...still not solved, it stays at 2 bars...then after about 30min. max it beeps, low battery!...
I need help, this is ridiculous....It cannot be just change the battery or chargerr, after a month of use???...
Also, i've ntoiced the phn itself is hotter than usual!...is something possible burnt out or wrong inside the phn?
HELP HELP HELP!!!!!
  • 24 Answers
Check out your battery and charger if not than hihg level repair needs to be done by a tech.
Posted on Jul 07, 2009
  • 39 Answers
I am thinking maybe it has the wrong kind of battery in it... or the battery maybe overpowering your phone...you can also adjust the power settings in your phone under tools...
if the phone has been dropped or hit hard ..you may want to replace the battery you can buy them cheap off of ebay.
  • 3 Answers
I have one just like that. it was because i over charged it. take out your battery when mine did that the battery looked a little bowed out on both sides. the salesman called it an exploded battery
SOURCE:
Razor suddenly died, have data & photos that I need to recover. Phone will not turn on, have tried charging and even put new battery in. How can I recover my stuff?
Take it to a Motorola service centre. The only way to get the data is to fix the problem. Isn't the data on it backed up anywhere, cloud storage, computer?
Motorola razr service centre Google Search
Aug 15, 2017 | Cell Phones
My motorola razor says unable to charge bought new battery cleaned out phone nothing works
in the settings menu,there is a place that has a charge time adjust.Turn it off so the charger will start charging the battery.This is a feature so you can set the phone to charge in minutes,if the bat is too dead,then it would need hrs charging.Thats why it cannot start.
Apr 02, 2010 | Motorola Mobility RAZR V3
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
Razor
HI,
Every phone battery has a life cycle. if the battery is more than year old , it most probably requires a replacement. As its not able to retain charge. If its under one year , get the same replaced from the motorola service center . I had the same problem with my razor and they replaced it free of charge as the same was under 1 yr .
Thanks
Proton
Apr 22, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Razor phone won't charge
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem.
New Batteries for Razors are around £6 - £7 online. google it.
Apr 16, 2009 | Motorola Mobility RAZR V3
Razor will not charge
my own razor does this also. the problem is the charging port on the phone. try using an electronics cleaner inside the port but do not oervsaturate. Otherwise if the phone is warrantied or you have insurance take your phone in and get it changed. I had a spare phone that i use to charge my battery. hope this helps.
Sep 11, 2008 | Motorola Mobility RAZR V3
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
210 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
