Question about Nostalgia Electrics KPM-508 Popcorn Maker
Not heating i have had one of these popcorn poppers since may 2007. it has worked GREAT until just a few days ago. it seems there is no heat in the kettle.what do i need to do to fix this problem? where do you need to go to get parts if needed?thank you clifford poplin
    Problem Solver:
  • 9 Answers
I actually just had a pleasant experience contacting Hellman Group, (The manufacturer of Nostalgia Electric popcorn machines). I called the main number, pressed 1 for customer support, and after 3 tries (got an answering machine the first couple of times), I got someone in customer service who was able to help me get the part I wanted.
The Helman Group, Ltd.
1621 Beacon Place
Oxnard, CA 93033
Posted on Feb 04, 2008
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
Popper does not work when plugged in
the heat coil shorted the fuse blew; throw it away
Dec 03, 2013 | Kitchen Appliances - Others
Popcorn machine doesnt heat high
Popcorn needs 400F to pop, if you machine is not hot enough it will not pop popcorn.
You did not include very much information to help fix it, but if it is a home use popper, you cannot repair anything on them.
A true commercial popper you can replace thermostats, and fix the problem.
Aug 12, 2013 | Kitchen Appliances - Others
We have a Back To Basics popcorn popper that has a broken piece. The piece is the clear see-through plastic top. Where can we find a new piece?
West Bend took over this company and no longer provides plastic window replacements. I fixed mine by super gluing the window and attaching a small strip of wood on top of the 2 plastic window pieces with small bolts (super glue pieces so wood can be properly attached because glue alone will not hold up to the heat). Not attractive but it works. (West Bend rep told me windows break because of high heat, but I only used mine over medium heat; I think they break at the spot where the raised lid hits the gear mechanism holder.)
Dec 11, 2011 | Back to Basics Popcorn Popper (PC6)...
Is the heater heating? Please check it ... Plug it into the outlet ... and put your hand GENTLY on the burner to see if it heats up. Of course, if it gets hot ... remove your hand.
I suspect the heater is not functioning 'pop'erly ...
Thanks for your interest in
Jul 15, 2010 | Back to Basics Disney Popper PD5 Popcorn...
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
May 03, 2009 | Cretors Goldrush Popcorn Maker
New Cuisinart Party Popper not heating
Align the tabs on the plate with the rectangular indentations on the base.
Squeeze tabs, set plate on base and release. This should lock the two pieces together.
Mar 29, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Nostalgia Electrics KPM-508 Popcorn Maker Logo
227 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Wayne Fellows
Wayne Fellows
Shehu Pro
Shehu Pro
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
