Question about Asrock 775VM800 Motherboard
Blue screen deep_pool_caller
  • 87 Answers
Well can ya give me some descrition how do u get blue screen probably by running any game or wat? if yes reset cmos install window again then the problem mite b solved if still its not then u myt have sum hardware problem!
Posted on Nov 18, 2007
Pool deep end
you might want to check with a professional to see if you can get a liner to fit that and it will be safe
Jun 24, 2014 | Pool & Spa
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
My baracuda classic falls on its side and stays that way being useless on the bottom of the pool. How do I solve this?
This information applies to a Baracuda G4 model only. My G4 would climb the wall at the deep end, lose suction, fall to the bottom of the pool and invariably land on its side or back.
The problem was the blue egg shaped buoy, as its called. Mine had signs of wear and there was even a hole in it. I replaced it and the G4 now works fine.
Feb 27, 2011 | Zodiac Pacer Pool Cleaner
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
May 08, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Compal fl92 notebook will not POST. DVD/cd rom works, lights come on power button and hdd starts, cpu fan spins then nothing happens from there. before this i had checksum errors,memory management...
well try to remove the RAM from its sockets and clean up the contact area of the RAM using eraser and repalace it and try to reboot it.
Good Luck.
Jan 07, 2010 | Computers & Internet
Cant enter windows xp because of Blue Screen (Bap Pool caller) and laptop does not detect hard drive to reformat
It may not be the hard drive at all. It may be that your RAM was damaged. If you can, try removing or replacing it and see if that changes anything.
Also, you can pick up a cable to operate the 2.5" HD as an external, USB drive. Connect it to another computer, and you should be able to run diagnostic and repair programs to deal with it.
Apr 20, 2009 | Acer Computers & Internet
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce:
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
May 08, 2008 | Compaq Evo N610C Notebook
Asrock 775VM800 Motherboard Logo
35 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
