Question about Evenflo Chase Comfort Touch
REMOVE CAR SEAT LINER
WANT TO RERMVE LINER TO WASH
  • 27 Answers
Most car seats have plastic clips around the edges that will come off. if you work around all the edges you can eventually get it off. The straps can be difficult to remove. Just pay close attention to how they came apart. Take pictures if you have to. They are a paint to put back if you don't.
Hope this helps,
XP
Posted on Nov 14, 2007
2006 dodge durango that does not have a sun roof that leaks water on the Head liner and seat belt and floor when it rains or I go thru car wash? What could cause this?
I just Googled a picture.
There is a roof rack type trim on the roof.
Water flows downhill
3 possible sources:
- window trim
- windshield
- roof trim
I would be suspecting the roof trim. Determine how it is attached. Remove it. Clean the roof and all parts of the trim that contect the roof. Apply sealant in appropriate locations. Re- install roof trim.
Test
No leak!
Ta-Da!
Apr 15, 2016 | Dodge Cars & Trucks
2006 dodge durango that leaks on Head liner and seat belt and floor when it rains or I go thru car wash?
3 possible sources:
- window trim
- windshield
- roof trim
Test
No leak!
Ta-Da!
Need to replace sunroof..
you need to replace glass or is it leaking if leaking then you have to remove upper seat belt covers pop off remove bolt 14mm and the trims on upper pillars pry off carefully held in by clips remove covers on interior light at front where sunroof switches are there are screws by bulbs disconnect connector remove center light cover and screws disconnect connector with clean hands remove rbber trim around sunroof opening and plastic cover on each side of sunroof glass held on with plastic screw clips then remove four 10mm nuts lift sunroof glass out of car remove cover and screws from rearview mirror all plastic trims around headliner move pass seat forward most and flip back rest all way down roll pass window fully down then slide headliner out of car now you can remove electrical connectors and remove water flow hoses from sunroof unit remove 8 12mm nuts holding frame to roof remove through door you will see the track sunroof slides on remove nuts along problem is silicone between track and frame is deteriorated lift track clean replace silicone reattach frame to roof dont put trims or liner in till test connect switches and glass to frame make sure sunroof works and closes fully then go through car wash to see if leak is fixed
Jan 13, 2011 | 2001 Subaru Legacy
How do i take the straps off to wash the cover?
Go from behind car-seat, undo belt on metal hook, then pull through the liner.
There is a hook at top and another at very bottom, just unhook the belt from hook and pull through
Aug 17, 2009 | Cosco High Back Booster 22-200 /22-207
How do you wash an infant carseat
first you will need to remove the liner of the carseat, you will have to carefully remove the small harnesses from the fabric but as you do so label the back with a sharpie or draw a diagram so you know how to get it back on!
wash the fabric on COLD only and dry on very LOW heat to prevent SHRINKING because it will be hard to put it back on if it shrinks!
wipe the seat with a dishcloth of soap and water, do not use harsh chemicals on the carseat itself as even if you let it air dry the chemical smell or any residue could make your child sick.
Jul 02, 2009 | Graco Baby Gear
Infant car seat liner
You can order replacement parts directly from Graco by visiting their website at
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
Nov 04, 2008 | Baby Gear
I need to know how to take the liner out of the baby car seat so I can wash it.
You have to unlatch the shoulder straps from underneath then unscrew the side handle to remove the elastic. Then your able to completely remove the cover. Just pay attention, because getting if off is the easy part, putting it back can proove difficult. Good Luck!
Jul 27, 2008 | Graco SnugRide - Giselle Infant Car Seat
Remove Seat to Wash
I still had my manual and it said to unscrew the back; and you do have to take out the top of the straps to get the pad off. I just did this last weekend and then re-install everything. It worked great! The only problem I found was that when the pad is washed, the pad backing gets caught in the velcro and needs to be removed.
Hope that helps!
Apr 07, 2008 | Evenflo Triumph 5
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Hello, Trevion -
I have not found any instructions or manual online for your model of Safety 1st child's car seat.
If you have not yet done so, I suggest you contact the Safety 1st company directly and ask your question.
This is the link to the Safety 1st Contact Us web page:
https://safety1st.zendesk.com/hc/en-us/requests/new?ticket_form_id=75009
Best wishes.
Feb 07, 2018 | Cosco High Back Booster 22-200 /22-207
Evenflo Chase Comfort Touch Logo
267 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
