Question about Whirlpool RF368LXKS Electric Kitchen Range
Whirlpool Model RF376LXBN Range
While my mother-in-law was attemping to auto clean the range ......She done something and the range door latch closed with the door open.
It now give a beeping sound with a Fault code but can't get the door latch to open thereforth not letting the door close.
Re-setting the power breaker does not help....it then come up with PF then goes back to the fault code and beeping.
Light on panel....labeled lock ....is lite up !
Please help on this..........What do I need to do to fix problem ?
Thank you
Artola
  • 1 more comment
  • artola Nov 12, 2007
    F 5 something........Can't remember the rest and I am not over at her house at this time. !
    Artola
  • Anonymous Mar 21, 2008
    whirpool range-accubakesystgem- oven can not turned off.
  • Anonymous Mar 23, 2014
    Don't ask me why, but my mom took the door off the stove and took it apart. Now she can't remember how to put it back together. Please help. Since I didn't see her do it, I have no clue how every thing goes back together. If someone could point me in the direction of the specs with pics, I could do it.
  • 473 Answers
What fault code is it giving you?
Posted on Nov 12, 2007
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The Oven and Range are working; however I have a F5 code on the display. Can you tell me what this means?
The F5 code means that the range door isn't latching properly (for some Whirlpool ranges). Check the latch when the oven is cool. If it is loose, tighten the screws that hold the latch. Try opening and closing the door to see if the latch is clicking shut properly. Then unplug the range for 30 seconds to a minute to reset the unit. If the error clears, you're done.
If the error persists, clean the latch area. With the oven not in use, rub the latch area with a cloth that you dunked in hot water and wrung out the excess water. Then dry with a paper towel.
If cleaning doesn't help, the latch probably needs to be replaced.
I hope this helps. Please give me the model number of your range for additional ideas. Whirlpool has the user's manuals for most of their appliances at their site. See http://www.whirlpool.com/custserv/index.jsp and the Manuals and Literature search box.
Jun 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven gas range is beeping and is displaying F5E1.
This is a problem with the door latch switch. You will need to remove, check for continuity with latch open no continuity closed should have continuity. If the switch has continuity with latch open replace. I have replaced quite a few of these over the years, they usually seem to go during a cleaning or right after the oven was cleaned. Enter your model # at www.appliancehelponline.com for an illustration. The switch is inexpensive and easy to replace.
Mar 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
We have a whirlpool glass top range.auto clean will not work. get an error code e-1 f-5. door doesn't lock and no heat. range is a style 2 model
Check door latch switch. located at the rear of the range. remove back panel. I believe that the assembly includes the lock motor, with micro switch
Jan 15, 2010 | Kitchen Ranges
Range with Error Code F5 E0
HI.The Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door)
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Jul 18, 2009 | Kitchen Ranges
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven door lock is stuck and buzzing
you can still use the oven i would gt someone out as soon as you can to get the lock released but yes you can still use the oven
Feb 04, 2009 | Frigidaire GLEF396 Electric Kitchen Range
Auto Clean not working
sounds like the door latch is defective. can you get me the full model # and i will confirm this with my information?
Aug 16, 2008 | Whirlpool SF367 Gas Kitchen Range
Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
Jan 02, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool RF368LXKS Electric Kitchen Range Logo
135 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
