Question about Supersonic IKONVERT Digital TV Converter Box
How do I play a program I recorded on pv?
I've pushed the colored buttons. I've pushed the play button. I've pushed the select (OK) button before pushed those other buttons.
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
I have a Panasonic VCR PV-V4202-A. I want to
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Sep 11, 2009 | Panasonic PV-V4022 VHS VCR
Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Jun 01, 2009 | Panasonic PV-GS19 Mini DV Digital...
All of a sudden our DVR won't record a show that is set for a season series. We have to set everything for one time only record.This just started this week. We don't know what to do.
what you will need to do to correct this problem is delete the series recording. in your list (push list button) highlight the program you wish to delete, push select go to "rec. series" press select. and delete ALL push select... get "ok" message, select again. and reset receiver on front panel of receiver there is a door you can open, hit the red reset button and then setup your series record again by going into the guide and pressing record twice. this will fix the problem by deleting ALL of the series record and resetting, and resetting up series record
Mar 26, 2009 | Directv (R10) DTV Receiver / 70-Hours...
I have a Panasonic PV-GS14 and it ALWAYS says 'Push Reset Button'
I had the same problem. In desperation, I picked up my trusty can of compressed air and aimed a few shots into the recorder/playback mechanism. Worked like charm.
Feb 18, 2009 | Panasonic Palmcorder PV-GS14 Mini DV...
I can't figure out how to bring up and watch a program i previously recorded on my motorola cable box
Look for a green button marked LIST almost in the center of the remote. If the List button doesn't work, be sure the remote is in the CBL mode (press the CBL button right under Master Power once)
When you get the list of recorded shows up, use the up and down arrow keys to highlight the show you want, then hit the OK/SELECT button. That should bring up another dialog box, look for Play and press the OK/SELECT button again to start.
Dec 12, 2008 | Arris DCT6200 DTV Receiver
Error message "push the reset switch"
The Panasonic manual for this problem is stupid. It says "Pushing reset button MAY help resolve the problem"...
nothing else-no explanation of possible problem.....worthless.....
Aug 10, 2008 | Panasonic PV-GS300 Mini DV Digital...
Push the reset button
let the camera sit alone for About 20 min,so that the camcorder automatically turned off. I turned it off, then back on and did not receive the reset button prompt.
if that doesn't work unplug the battery and all power and plug back in.
Jan 28, 2008 | Panasonic PV-GS150 Mini DV Digital...
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Supersonic IKONVERT Digital TV Converter Box Logo
76 people viewed this question
Top Supersonic Televison & Video Experts
Steve Allison
Steve Allison
Demonic-2011
Demonic-2011
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
