Cars & Trucks Logo
shane Posted on Dec 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear hatch won't open.how can i fix this - Cars & Trucks
Gregg
Level 3:
Master:
  • Cars & Trucks Master 362 Answers
  • Posted on Jan 02, 2015
Gregg
Level 3:
Master:
Answers
362
Questions
0
Helped
91470
Points
1014
The following advice is not a joke. I am very serious:
Place a towel on a spot over the lock catch. Now, with the ''ball'' of your hand (face of your hand just above the wrist), _bang_ as hard as you can without denting the metal. Do this about three times, quick and hard as possible (Bang! Bang! Bang!). Then try opening the hatch. This usually works very well. And it also works on stuck hoods. If it doesn't work, try it again a few times. It is now Winter and a ''Summer Bang'' will obviously work much easier. (Good luck)
5 Related Answers
Anonymous
  • 776 Answers
  • Posted on May 27, 2009
SOURCE: handle on rear hatch door broke off.how can i open hatch door until i can get a new handle?
you don't. take it into a Hyndai Dealership and have the handle repaired/replaced. The rear hatch panel/cover has to be removed (from inside the vehicle) to access the hatch latch and open the door.. from that point the handle can be replaced/repaired.
nathan
  • 634 Answers
  • Posted on Jul 16, 2009
SOURCE: Rear hatch and window won't open on Blazer
sounds like a blown fuse, open drivers door and look at side of dash, fuse panel is there check fuses
Anonymous
  • Posted on Mar 09, 2010
SOURCE: rear hatch 2005 chevy tahoe is locked & won't open
my 06 tahoe just got this problem...all other doors lock and unlock with the fab and door switch...but the hatch is in permanent locked mode. i cant even unlock the hatch window. why is this happening?
Anonymous
  • 229 Answers
  • Posted on Oct 19, 2010
SOURCE: Rear hatch wont open with remote or close by
In my vehicle there is a botton in the glovebox that gets accidently switched off. there is a child safety button to prevent automatic door closing...highlander may have this switch as well.
Anonymous
  • 786 Answers
  • Posted on Aug 17, 2012
SOURCE: Kia Sorento rear hatch won't open
could very well be a fuse....check this......need more help fill free to contact me........good luck.
I need to fix by ail lights but cannot open rear hatch. How can I access this frm inside
You can't. You have to get the hatch open. Pull the top trim off the hatch. Remove two screws , one on each side. Pull the bottom panel out and reach down and grab the rod or arm to open the hatch. Then you can access the screws to remove the rear lens. Fix the hatch since it is open.
2010 yukon rear hatch won't work automatically
Check the hook and latch for any obstructions or sticking. Also check remote button for semi sticking.
2answers
1helpful
Hatch won't open
Go into the rear hatch cargo area and remove the trim panel over the latch and trip it manually. I know this works have done it myself on my 1996
REAR HATCH WON'T OPEN 08 HSE SPORT
Hello my range rover sport tailgate glass won't open so can anyone give me advice how to fix it and tell me what the problem is exactly if it is a fuse or something. Can you please text me on 07455527235 to tell me how to fix it or what the problem is. Thanks Shayaan
Rear hatch won't open on 96 jimmy
does it work w/ the key or just the remote is inop?
2005 GMC BACK HATCH WON'T OPEN
It sounds like the lock actuator has failed or has a poor connection which won't allow the latch to release. What you will need to do is remove the inside rear hatch panel to access the lock actuator. Once you get to the latch use a flat screwdriver to release the latch being careful not to damage the glass.
Click this link below for more troubleshooting:-- http://technoanswers.blogspot.com/2011/09/rear-hatch-wont-open-on-2005-gmc-yukon.html -------- This will help.Thanks.Helpmech.
My rear hatch light indicates that the hatch is open which it is closed tight. Because of this my interior lights stay on and my remote start won't work. How can I fix this? My jeep is the 2009...
The switch on the latch is more then likely stuck. If you can see it spray it with some electrical cleaner and open and shut the hatch a few times.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
