Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Oven door just barely closes- light stays on
My oven door does not seal tightly. It often does not even close enough to trigger the oven light to go off. Any suggestions as to how to adjust this?
  • 3 more comments
  • heggie91 Jul 06, 2008
    Same problem door dose't close..light stays on....HELP 790 9642 9401
  • Anonymous Jul 20, 2008
    Same problem I ajusted the front legs to have the stove lean back more Helps but didn't solve problem completely
  • Anonymous Mar 17, 2014
    When closing the oven door, the light does not turn off
    When closing the oven door, the lights inside will not turn off. The switch was replaced but no change.
  • Anonymous Mar 29, 2014
    How do I adjust the oven door. It does not close tightly.
  • 126 Answers
Put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Posted on Nov 23, 2007
I have the exact same problem with Kenmore stove. How do you actually get the hinges off?
Posted on Oct 26, 2008
Sears should have a recall as these ranges  were built with faulty hinges that do not allow the oven to close properly and the oven does not retain temperature.
The repairman told me that Sears is well aware of this problem but will do nothing about it.
It is 200 dollars for new hinges. Our stove is a little over a year old and the total cost for hinges and replacing the digital display was almost the price we paid for the stove.
Posted on Feb 01, 2008
  • 473 Answers
This is a fairly common problem on some models. You will need to replace the door hinges. If you give me the complete model # from the sticker on the range I can give you part #'s and pricing.
Posted on Nov 12, 2007
Oven door does not stay closed tight enough to keep light off or to keep open door light on heating
Sorry to read about your problem, I hope this helps you out.
you have a spring/hinge problem. or a small chance, your door seal is defective.
you may try to remove the door and re-seat it...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Whirlpool RBS305PD Electric Single Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
Oven door not sealing?
These doors have springs to shut them. If you can figure out how to get to the springs usually you will see that one is either unhooked or unattached at one end. If broken on the end bend another hook into it and add a pice of wire long enough to make up the broken difference.
Jan 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Oven door does not close properly
replacing hinges on this oven. Take a look.
Dec 14, 2008 | Hotpoint RB787 Electric Kitchen Range
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
Nov 06, 2008 | Ovens
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
1,661 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
