Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
    Problem Solver:
  • 6 Answers
Please summit model number and maybe i can help.
Posted on Nov 14, 2007
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
My carrier hotel style heat/ac unit just blows cold in electric heat or heat pump setting
check the thermostat also check the inline fuse for the electric heat coil . check wires in control panel they tend to burn and last check to make sure reversing valve is changing over located by the compressor
Mar 05, 2015 | Carrier Heating & Cooling
How do you wire a transformer on a carrier unit?
depends if gas or electric on gas u have 120 volts if u have a universal transformer u will hve several wires and on the transformer it will say 120one color 240 another color and common is one color hook black wire to 120 wire and common to ur white wire from unit and ur 2 low voltage wires dont matter if it is electric use the 240 wire and common wire wires from unit dont mater just use the same 2 wires u unhookes and low voltage wires dont matter best advice is to put a 3 amp fuse inline on the low voltage side cause something caused the ransformer to go out and its probably a shorted wire this will blow the fuse instead of burning up the transformer
Feb 23, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Horrible awful noise coming from carrier heat a/c wall unit!
I watched your video on youtube. Sounds like a seized compressor. Do you know if it is reverse cycle or electric heat?
Jan 18, 2010 | Carrier 52PQ307 Wall/Window Air...
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
66 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
