Question about RCA HD52W59 HDTV Projection Television
I have a rca projection 52 inch 3 lenses power comes on but picture not .... is there bulb or some thing i need to find and replace or fuse some where
  • 273 Answers
Hi Buddy
there are a few things that can cause this symptom but we need to go back and regroup .
let's go at this from a technical stand point .
when you plug the unit in and turn it on what do you see the led's in the area of the power button and pay close attention to the blinks if there are any . then we can try to get you on the right track .
also id guess you already have the back of the set off ?
if so on the large board on your left side looking at it from the rear of the unit . there are some caps that we should look at cp150 cp130 cp120 if i remember correctly . what your looking for is the bulged cap that some many hit on and true its a problem but if it hadn't been for caps failing they may never have fixed them .
one word of caution is not to push the power button excessive at this point if there is a loss of deflection you may well damage one of the crt's or picture tubes this unit has a red crt blue and green and they provide the screen lighting and video you see .
with you behind the set perhaps you could have some one push the power button and listen to that high voltage transformer on the left side board it has a red wire coming off of it . and be cautious there is possible shock hazard there .
and if you have access to the caps i would change those caps right off the start as they are most likley defective as well as other possibility then let me know what you find and il see what i can do to assist you
Tim
Posted on Dec 31, 2014
SOURCE:
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
  • 9 Answers
SOURCE: 52 inch rca hdtv rear projection
Replace the vertical output IC (DL032) on the deflection board. It is mounted on a heatsink, in the middle of the board. That is usually the culprit on the ITC222 chassis for bowing problems. Also, check the solder connections on the flyback transformer.
Posted on Nov 01, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
  • 5 Answers
SOURCE: rca 52 inch projection
I had the same problem with the power button blinking 3 times and not coming on. I took this advice and changed the flyback 259296. That did not work. I also took the advice of superman276 and changed the cp150 and my tv works now. Flyback is $60 and the cp150 is $2. I pretty much wasted my money on the flyback.
Posted on Feb 01, 2009
SOURCE: RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Posted on Nov 07, 2009
I got sound but no picture on my 52 inch rca floor model tv i sure its the bulbs but not sure how can i find the prices or the rite bulb for it
That set is a 1994 model set. You have 3 picture tubes in that set of which are no longer available or made anymore.
Nov 27, 2010 | RCA P56830BL 56" Rear Projection...
RCA 52 inch. projection t.v. deflection module repair. Power indicator light comes on flashes 3 times but no picture or sound.
Try website like Tvrepairworld.com buy one their RCA capacitors kit,they put together.The instructional cd came with it,will detail which capacitors require changing.
Sep 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is getting weak can I buy a light for this model d52w
the dw52w20 is a CRT based projection tv ... it has a small very bright picture tube inside to produce the picture which is focused onto the large screen .. so there is no light bulb that can be changed ..there are several things that can cause the picture to become weak ... first, dust build up on the CRT (picture tube) and associiated lenses and mirrors will cause the proplem ... cleaning those will almost always help .. the dust will cause the picture to be weak and a bit fuzzy, sometimes cloudy ... next, because the CRT is driven so hard to produce the large 52 inch image then its life is not as long as normal picture tubes ...it will weaken with age ... your model has had some trouble with convergence .. thats where colors tend to seperate .. that was a good tv in its day and had wonderful capabilitys but now it cant compete with modern sets ... the new ones use less power and are much brighter but you will have trouble finding one with a better picture ... brighter yes ..sharper yes but there was a smoothness (dynamiic range) about the CRT type sets thats hard to beat... unfortunatly service bills for your set have been getting pretty high .. at times approaching the cost of a new set ... that and the fact that TV prices have dramatically come down, makes a fix or buy decision easier if its in the budget ... if you are really handy then you could clean the CRT, lenses and mirrors yourself but make sure its unplugged for an hour first ... there is very high voltage in there otherwise ..
here is a manual for your tv if you need it ...
http://tv.manualsonline.com/manuals/mfg/rca/d52w20.html
Apr 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do i take of the front cover of my 52 inch RCA hdtv? i need to clean out the inside of the tv because spiders somehow got behind the picture...
You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
Dec 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with 52 inch RCA projector t.v
It sounds like the CP150 and or the CP114/120 capacitors need to be replaced, they cost around 3 dollars each and can be found at Radio shack or you can order them from http://servicemanuals.vstore.ca/ and they will send instructions with them.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV 52 inch RCA projection
The red picture tube is shorted. Huge job! Maybe not worth doing.
Apr 09, 2009 | RCA HD52W151 52" Rear Projection HDTV
RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
1993 52 inch rear projection rca tv
i have this kind of tv1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Nov 03, 2007 | LG RU-52SZ30 52" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
