Question about Boating
Need wiring diag 4 90hp 1997 evinrude. Old switch numbered 1 to 6. New switch standard replacment part has letters SMBCAM, have my wire colours need diag or translation please
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Evinrude lanyard switch/emergency stop circuit wiring diagram
Need wiring diag 4 90hp 1997 evinrude. Old switch  - 25346772-ho51m1k20agycxa4dcrhpmxi-2-0.jpg
Posted on Feb 05, 2015
5 Suggested Answers
SOURCE:
  • 5692 Answers
SOURCE: 3 wire tilt/trim installation help
If you have a multimeter which can cost less than $10 or a test light. What you want to do is have the up button pressed and see which 2 wires have power. The 3rd wire should not have power. Then press the down button and see which to wires have power. It should change. Most likely the black is common and feeds power to the switch. When pushed up the blue gets power. When pushed down the green gets power. You may have to provide a ground to the motor from the battery.
Posted on Jun 13, 2009
  • 3 Answers
SOURCE: iam looking for a wiring diagram for a 1964 40
Here is a link to the diagram you need.
http://www.maxrules.com/graphics/omc_pics/wiring/61_66_40HP.jpg
Posted on Apr 28, 2010
  • 64 Answers
SOURCE: replace a 1998 Johnson 115 engine with a 1989 Evinrude XP 150
Change controls and gages with the engine if you can.
Posted on Apr 29, 2010
SOURCE: need wireing digram for 40hp evinrude boat with
have a 40hp evinrude selectric push button motor starts on key shift in gear throttle full hardly any speed, put key on off position and the engine reves very high so i have to throttle down but won't engage put key in on position and it engage no speed.
Posted on Jun 23, 2013
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
Can I replace my old Magic Stat CT3100 thermostat with a Honeywell CT3200 thermostat?
yes just make sure u relace all the wires in proper order, r-rc, w , y g,, remove one wire from old stat and install on new one or make drawing and write down all wireing colours and letters
Dec 21, 2015 | Honeywell Heating & Cooling
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
C / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
Replaing old double switch with two black and one red wire with new leviton double switch. For two light sources. help!
1) More information is needed about switch that is being replaced, and model number of new switch, and what you want to do, and what each wire goes to.
http://waterheatertimer.org/How-to-wire-switches.html#double
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 10, 2013 | Electrical Supplies
Hi! Please help me. I am having trouble connecting the wires from my dead 220v T104 pool pump timer to a new 220v T104 timer. The old timer had posts marked G 1 2 3 4. The new one has posts marked L 1 X...
Open following link for T104 wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Your new timer is L 1 X 2, so that is not Intermatic T104.
You might have GE/Tork 15061 that fits into Intermatic box.
http://waterheatertimer.org/GE-timers-and-manuals.html#GE-replacement
First thing to check is if new timer is 240Volts to match old T104.
If new timer is 240V, then here is crossover:
"Old 1" goes to new L >> and notice that L and 1 are connected by brass bridge. If bridge is missing, add a jumper wire between L and 1 on new timer
"Old 2" goes to new 2
"Old 3" goes to new X
"Old 4" goes to new X
T104 Intermatic timer is SPDT single pull double throw, so it turns off both wires going to Load.
New L1X2 timer is SPST single pull single throw, so it turns off one wire going to Load, and that's why old 3 and old 4 both connect to terminal X.
If this is too complex, then add a comment or buy new trippers and a new WG1573 clock motor and repair T104 for $20.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Apr 22, 2011 | Intermatic T104 24h 208-277v Mechanical...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Telephone wall jack
Did the old wall jack work before you removed it?
Are the wires still connected or do you remember where the wires used to go.
If so, then what I would do, is with a phone connected, start disconnecting 1 wire at a time. When the line goes dead, then you know that is one of the wires that you need to use. Reconnect that wire, and mark it, and Keep doing this until you find the other wire that makes the line go dead.
Then you will know which 2 wires you will need to get the jack working.
Usually, the standard color wires that you need for the new jack is Red and Green for a single line phone jack.
Hope this helps.
Good luck.
Mac
Feb 21, 2008 | Lands Phones
Boating Logo
481 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
