Question about iRiver H10 MP3 Player
Iriver H10 20GB
Tried to install some music and screen has locked up and has USB Connected on it. Now I can not turn it off or do anything with it and my computer will not read it now as well. All the help I can get will be great as its for daughter to take away with her. Many thanks
  • juh10 Nov 13, 2007
    When I try to sync song to my H10 it comes up with; windows media player encountered an unknown error. this can occur when another programme or operating system encounters a problem. It will not sync the songs. it then says USB connected and freezes.
  • 8,596 Answers
Simple reset should do the trick - remove and reinsert the battery.
If the problem persists, check the iRiver website for a firmware upgrade - their site is not the most user-friendly but it is CHOCK FULL of information.
Here's the link to the manual:
http://www.iriver.com/support/down_view.asp?searchProductIdx=61&searchCategoryIdx=2&searchString=&page=1&idx=710&tmpSearchProductIdx=&tmpSearchCategoryIdx=&tmpSearchString=
Posted on Jun 13, 2008
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
Feb 22, 2011 | iRiver E10 Digital Media Player
Does not open the iriver E10
I can not upload song in my e100.......... explain me all process of upload song in my ipod & not open in my computer.....
The iRiver E100 uses iRiver Plus 3 to manage music, pictures, and more. iRiver Plus 3 can be downloaded for free here:
http://local.iriver.com/mas/download/downloadView.asp?selectPart=cateCode&findWord=01&sno=852&page=1&cateCode=01
  1. Insert the installation CD into your PC to display the installation process screen.
  2. Select iriver plus 3 and click the Install button.
  3. Complete the installation process by following the on-screen instructions.
  4. Turn on the iRiver E100, and then plug it in to the computer using the USB cable.
  5. Open iRiver Plus 3.
  6. Select the desired files / folders in your PC and drag & drop Music, pictures, etc. to the drive which appears as the product.
If you would like, there is a manual available here:
http://211.39.137.201//download.asp?filename=2008111114270150302.zip&filepath=/file/Down/
Jan 23, 2011 | iRiver E150 (4 GB) MP3 Player
Iriver plus 3 not recognising iriver x20 player
try to upload the songs onto it with windows media player 11 i only use iriver plus 3 for videos
when ur in windows media go into sync then it has like a side bar just drag the music into that and down the bottom of the bar it says sync press that
and if that doesnt work u might have to buy a new one
Aug 29, 2009 | iRiver X20 MP3 Player
I have a problem whit my player
K, on day when i turned on my iriver, it says "system files missing, to restore the system files, connect H10 to iriver plus." so i connect it to iriver plus and the iriver says "USB connected" but iriver plus doesnt recognise t, like it is not connected, i have tried what other soloutions were given, but the iriver doesn't appear on my computer, but it does on safetly remove hardware, i have downloaded the newest version of iriver plus and it still doean't work. i cant get it to do anything now, not even turn off with =out takinging the battery out
Jan 29, 2009 | Samsung YP-S3JAB Digital Media Player
My iriver plus3 software does not detect my iriver h10 player
GUYS ALL YOU HAVE TO DO IS PUSH THE USB CABLE HARDER INTO THE DEVICE. IM A GENIUS!!
Oct 15, 2008 | iRiver H10 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
Iriver Clix USB freeze
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
Feb 17, 2008 | iRiver Clix Digital Media Player
E10 "Emergency USB" fault
I have had the same problem many times and would like to see an update tothe firmware to fix it. Here is what I did. Rurn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a staple. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit turned off.
I hope this helps.
Sep 21, 2007 | iRiver E10 Digital Media Player
iRiver H10 MP3 Player Logo
76 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
