Question about Sanyo VWM-800 VHS VCR
I Am Having Trouble Tuning My Channels On My VCR.
Hi, I was trying to tape a figure skating even on ESPN, and my VCR would not even recognize that channel. I tried adding all of the channels past 12 back, but I still got a blue screen . Can you help me find a manual for my model ? Or help me solve this problem? It was working great up until today.
Thanks,
Suzanne
    Problem Solver:
  • 10 Answers
Hey is the VCR set for cable? even if it's not a local channel
could try to come in. turn the blue screen off on the VCR that
might solve your problem. If the channel is weak the blue screen will come on and block it. you can turn it off by going into
your VCR settings. Also If the cable is weak a splitter will
cause this you might have to hook the cable up directly to the
VCR to record it and watch it through the VCR. that's was may
problem once.
also you can tune channel 12 to your VCR manually if it is too
weak because of a nearby local channel it won't tune in automatically.
Posted on Nov 13, 2007
Hi there, Having some trouble with the Sony SLV-SE830 VHS VCR. It should just work once the power is switched on and the SCART lead is connected to the back of the TV and the AV channel is set to the...
If you tv has more than one SCART connector.. ensure you have the cable plugged into the proper one.
Not sure what the problem is.. if you have a modern bidirecitonal SCART cable properly connected.. you should be able to view and hear the tape as it plays.. assuming the machine is in good condition.
Of course if you want to record a program other than the one you are watching you will ned to supply an independent broadcast signal to the VCR.. and yes you may have to program the tuner on the VCR if you want to record.
However if you simply wish to view tapes.. you shoud be set to use the machine as connected.
Best of Luck!
Apr 08, 2011 | Sony SLV-SE830 VHS VCR
My jvc HR D170 ES vcr used to work fine when suddenly the picture ( snow ) is very bad but sound is ok ...tried to retune to my tv ...tried changing the rf at back ...tried tuning to my other tv and...
The vcr is fine. buy a cleaning tape. people say dry cleaner tapes wear out the heads, but it fixed my problem when my vcr only showed snow. but try a wet tape first. follow the instructions that came with the tape and run it a few times.
Jun 26, 2010 | Televison & Video
Sony SLV-640HF Problem
I would be inclined to say that there are only two likely problems that you may be encountering. Either you are getting a bad signal feed, or the connectors on the cable are getting old and need replaced. The connection to the cable can break down over time, especially if they have been connected and reconnected several times. I cannot rule out problems caused by the transition to DTV, but that doesnt seem likely if there are only a few channels affected. As far as "selective failure" of the VCR's built-in tuner, I would say that that is also a very unlikely source for the problem If the tuning components inside the tuner had gone out, I would expect to see a problem on all channels watched through the system. If you are having this problem on all channels of the sony, then the tuner could surely be the problem, but if you haven't used it much that would indicate a problem at manufacturing, however since at least one of the machines is working fine on some channels and not on all of them, I would suspect the connections or the signal from your cable company. Contact them first ands see if they are having signal issues, if not try replacing your connectors.
Dec 26, 2008 | Sony SLV-N55 VHS VCR
Tuning channels in VCR mode to record
wich deice are you trying to record shows onto the vcr or dvd recorder? what is the brand and model of the unit?
Dec 19, 2008 | Televison & Video
Had dish network update - can't view vcr tapes
the output of the vcr...
what is it physically wired to?
Dec 04, 2008 | Sanyo VWM-950 VHS VCR
Dvds recorded on Samsung will ONLY play on Samsung
Have you finalised the disc before trying to play it elsewhere? If not this could well be the problem. The option is the menu.
Hope this helps
Jul 27, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Tuning a Funai 31B-250 VCR to a Wharfedale L22T11W-A LCD TV
i have a wharfdale L22T11W-A LCD TV. have got sound but no picture, any ideas?
Dec 22, 2007 | Televison & Video
Tuning in to TV with wireless headphones
I need more info on this. What type of tuner and receiver? Is the tuner plugged into the headphone jack on the tv? If you have a tuner for tv that tunes in channels 2,3,5,12,25,60 etc that would be an older tuner that used the older NTSC standard. Tv stations now broadcast using ATSC, channel 4,1, 4.2 etc.
Dec 25, 2017 | Jensen Radio Communications
I am having trouble channel setting and recording.
If you have a bad or fuzzy picture when viewing tapes on VCR then you need a new video drum. I think you can buy another that is for your brand on the internet. More VCR Repair -
http://www.videouniversity.com/vcrfirst.htm
Oct 03, 2007 | Aiwa HV-MX100 VHS VCR
Sanyo VWM-800 VHS VCR Logo
267 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
