Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
Audio box flashes on screen {mono/stereo}
A box appears on the upper right side cable/analog
*stereo/mono
we have digital cable why is my tv showing analog
why does the audio switch from mono to stereo {mono being the main one}
it doesn't last long but flashes on the screen very often.
also my dvd player doesn't have as good a picture as when i had my old tv
colors are not good looks, grainy
  • jimtnc Dec 11, 2007
    Sharp Aquos LC-46D64U question
    There is a small blue audio window that keeps popping up in the top right-hand corner that has Cable Analog, then Audio : Mono. The mono keeps flipping briefly when a stereo signal comes through. Is there any way to either set this to stereo or something to keep this dadgum box from continually popping up?? It's distracting as hell.
For some using composite wires instead of the coaxial may not be a possible because you use the red,white,and yellow spaces for your xbox or playstation. Here is another solution if you use digital cable or a similar cable box. This may work for many other cable boxes. Go to your cable box's settings and look for an option to change your "Audio Range". which is probably right now set on either "normal" or "narrow". If this option is on "narrow" then change it to normal and monitor the results. If you continue to recieve this problem then change the setting again to "wide". This should eliminate the box all together. If anything you might only see it once or twice in the entire day instead of ever 20 secs like mine was. I sincerely hope this is helpful.. Let me know.
Posted on Dec 24, 2008
I am having the same problem with a LC-65D64U
Getting a new HD Cable Box on Friday.
Hopefully you guys are right! :)
THanks!
Posted on Jan 07, 2008
Nope. I found out what the problem was...cable box settings. If you just drop by the office and pick up a cable box without them installing it for you, be sure to get instructions on how to set it up, because it is not set up for HD. That's what my problem was...maybe won't apply to others, but just passing it on. Thanks.
Posted on Dec 31, 2007
    Problem Solver:
  • 17 Answers
You may have digital cable, but you are still on an analog cable channel. If you change the connection from the coaxial (the one that screws on) to either a composite (red white yellow) or component (green blue red, red white) connection, that will get rid of the annoying box.
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
QUESTION!!!
It may be a setting on the TV some stations only broadcast in Mono. But most likely check your tv settings and make sure it is in stereo mode.
Dec 22, 2008 | Sharp Televison & Video
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
42" Sharp Aquous audio; Mono vs. Stereo
no. that is not true. the person you spoke to obviously didn't know what they were talking about. you mean to tell me that everyone that has a cable or satellite box with a stereo or hd tv is not going to receive stereo sound? really,think about it. you only need a cable box( for now ) if you have premium channels (hbo,showtime etc). you can connect the cable line right into the tv if you only have basic cable. look at the back of your cable box. if you have a red, white, & yellow audio/video output, then the box is stereo.connect these outputs to your tv. this connection however is not hd.you will need a hd box with a hdmi cable for hd .To put the tv on stereo mode, there should be a way via the menu and/or the audio button on the remote to get it off mono and put it on stereo. your manual should at least show you around the settings of your tv.
wg
Apr 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
960 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
