i bought Metra Ltd 70-7001 adapter for my Mitsubishi galant of 2000 !i connected the adapter to my new JVC KDR-200 CD Receiver ! the radio turns on and i can go to the menu and all that but i cant hear any sounds !my old radio emits sound but the new one doesnt! please help me out !what could be the problem ???
First check all of the connections between your receiver harness and the Metra. The colors should match up. Then check each wire from the Metra harness to your vehicle wiring against the vehicle color code found here. If everything checks out, try resetting the receiver. Remove the faceplate (press the button at the lower left) and starting with the left side, gently pull the faceplace off. Now, using a ballpoint pen or similar object, press the reset button (Just left of the right edge near the bottom is a small hole with the reset button behind it.) for 1-2 seconds.
If this fails and you still have no sound, I'd suspect that the receiver is defective.
Hope this helps. If it does, please rate as "Fixya".
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mitsubishi Metra Ltd 70-7001
the newt kit worked once! thereafter it seems to get stuck as above. Do you have any advice? Do you...
(More)
the newt kit worked once! thereafter it seems to get stuck as above. Do you have any advice? Do you know if the manufacturer will replace or fix inside a given period? Our In-Car DVD - 273 was purchased from Argos in July 09
2001 Cadillac Catera the cd/radio shuts off (sometimes back on) by its self sometimes when the cd...
(More)
2001 Cadillac Catera the cd/radio shuts off (sometimes back on) by its self sometimes when the cd player stops the radio comes on other times it just shut off completely and starts working again later
