Computers & Internet Logo
Kevin Teague Posted on Dec 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell inspiron 1520 will not charge the battery, if i can charge the battery some how then when its pluged in will stay charged, but if laptop gets un pluged it will not recharge, have switched chargers still does samethimg?
KiranK
Level 2:
Sergeant:
  • Dell Expert 352 Answers
  • Posted on Dec 31, 2014
KiranK
Dell Expert
Level 2:
Sergeant:
Answers
352
Questions
0
Helped
47607
Points
886
Hi Kevin Teague,
There is possibility that the battery may have failed. Try following the below steps and let me know the results:
    (1)Run an online diagnostics using the below link:
    http://dell.to/189uUNy
    Click battery life and run diagnostics
    Make a note of the error codes that appear (if any)
    (2)Try using a known good battery and check if that makes any changes.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Laptop pluged in but wont charge
your battery is dead, try and replace it with another one and see if it charge.
Dell inspiron 1525 pluged in not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
3helpful
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
I have an dell inspiron 1520 laptop that will not turn on. battery is fully charged. What should we do?
Do one thing, remove the battery from the laptop, connect to AC Power directly with out connecting the battery, then try to switch ON the laptop. If it got switched ON then there is problem in the Battery. If not it may be problem in the Power button or in the Mother Board.
Battery dell inspiron do not charge, the comp work if he is pluged in but he does not charge the battery
I also have the same problem with my DELL Inspiron 640m. But when I replaced the BATTERY everything works fine.
Please visit the following site to know the price of your battery
http://accessories.us.dell.com/sna/batteryconfig.aspx?c=us&l=en&s=bsd&cs=04
Always buy genuine DELL Battery.
Please rate. Thanks. Let me know if you need more assistance.
I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
2answers
My laptop wont charge
Sounds like to me you may have a bad battery. I would do a search for your model number for a battery. It is showing being plug in that means your charger is working, but your battery not taking no charge.
1helpful
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
2answers
Dell batteries.
Its time change ur batteries
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
