I have cleaned all the lence which can bee cleaned opening the top cover i did not went into depth by removing any thing it has red ting and the picture is slightly dim and one black small spot in the middle of the screen how to fix it
SOURCE: blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
SOURCE: sony VPL CS6 in darkness !
Make sure the interlock switch is activated by the cover of the lamp.
Can't measure a voltage with the lamp cover open. High voltage is powering the lamp from an smps or ballast supply. If lamp is New, cover switch is good, then the lamp power supply could be faulty.
Siliconchip.
SOURCE: Lampcover brightining
Hi there
Your Projector needs a new lamp and do remember to reset the lamp timer after replacing the lamp .
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Testimonial: "Thanks very much for the help. "
