The conditioner is not being pumped through as normal on wash cycle? Is this a blockage that can be fixed easily? Cheers Steve.
It's an Aquarius WML 730 Model.
I'm hoping once the lid is off the access to the pipe/other that feeds the conditioner to the drum can be looked at. Could it be an electronic programmer fault?
Re: The conditioner is not being pumped through as normal...
Do the cheap things first. Remove the top and check the supply hoses for blockages or kinks. Get a length of springy plastic to thread down the hose to see if there is dried residue. When the top is off try a cycle that uses conditioner and see if it tries to empty the tray.
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage... Hotpoint WML 560 Instructions For Use Manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board. ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners. Hope this helps.
You probably got something in the filter... blockage most likely or you have a faulty drain pump.....
to check remove the waste pipe and lower it ground level if the water does not drain out due to gravity then you have a blockage and if it does drain then the most likely problem is a faulty drain pump...
The filter is located at the bottom of the drum and if you remove the rear panel it is easily visible and accessible so you can do this one yourself..
anyways if you need anymore help let us know cheers
