Question about Cameras
My vivicam 3765 is very slow to "recover" between pictures and sometimes freezes up. Can the firmware/drivers be reinstalled in camera? Would this help?
    Top Expert:
  • Cameras Master
  • 6,705 Answers
It won't help. and read my other post, if the camera is not fully functional, don't try to put in other software. When Vivitar never gave a firmware update, you can't even get any firmware.
Posted on Dec 29, 2014
4 Suggested Answers
SOURCE:
Bubbabear64
  • 2794 Answers
SOURCE: vivatar vivicam 3765 camera
Here you go:
http://www.vivitar.com/ecms.aspx/052e28fc-27d1-4bb7-9650-27b4498c20f2/SupportFiles/Man_Eng.pdf
Posted on Jun 21, 2008
SOURCE: Vivitar ViviCam 3765
I found a plastic top which fits and acts as a lens cap.
Posted on Jul 15, 2008
SOURCE: AC adapter for ViviCam 3765.
The polarity is correct, but 400mA is not enough. One commercial supply I saw was rated at 2.5A. I even suspect 3v isn't enough as I have tried an external battery pack with D-Cells in it and after a few flash shots it wants new batteries. The camera itself seems to be over-sensitive to "low" voltage and complains about new or freshly charged batteries (see other posts).
There is a problem with these cameras in this battery voltage area. I have asked Vivitar what external voltage to use, but no reply. Good luck! I am sufficiently fed up with this camera that I may try 4.5v external supply and if it blows up, good riddance!
Posted on Jun 19, 2009
Can I install firmware on a vivicam 3765?
Firmware only can be installed on a fully functional device. It is wrong to think you could put some firmware into a device, without the special programs the manufactures uses. When a firmware is made available for a camera, it is most of the time put on a memory card. It has a certain name and size. The camera must function for 100%, because the software has not only to recognise the file where the firmware is in, it also must place the software in the flash memory, without an error. For that it only has one chance, of always make sure there is enough power available to transfer and to install the firmware. When things go wrong, you bricked the camera and the only thing you can do is bring it to a certified service centre. Camera's in warranty, will be flashed for free, but out of warranty, it could be they charge you for the job.
Dec 29, 2014 | Vivitar ViviCam 3765 Digital Camera
Can the firmware/drivers be reinstalled in a vivitar Vivicam 3765? (In camera not computer) Camera is very slow to"recover" between pictures.
No it cannot. If this is something that started happening recently make sure you have a compatiable SD card and that it has been formatted in the camera. You might also try resetting the camera to factory defaults. The feature is located in the menu options.
I'd use this opportunity to get yourself a newer model. That's a pretty old camera and the quality is poor at only 3MP.
Dec 29, 2014 | Cameras
I need a driver for a vivitar vivicam model 3765 digital camera.It worked with with windows XP but not on windows 7
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 15, 2011 | Vivitar ViviCam 3765 Digital Camera
Does anyone know how i can use my 3765 for a webcam i'm desperite i called vivitar and got the runaround. please help
You can't. The 3765 was designed as a camera, storing high-resolution images (and videos) to a memory card. It was not designed to stream live video to another device.
Jul 11, 2010 | Vivitar ViviCam 3765 Digital Camera
No installation cd-rom for Vivitar Vivicam 3765!!!
The best I can do for you is give you the number for vivitar support. I have looked to see if I could find the installation files and no luck. I am pretty sure that Vivitar can help you. Best wishes.
Customer Support [email protected] US: 1-800-592-9541 UK: 0-800-917-4831
Sep 17, 2009 | Vivitar ViviCam 3765 Digital Camera
Date stamp will not appear on photo. i was told that there is on/off setting for this in the general setup menu called "date stamp" however,the model "vivicam 3765" has no such setting. how do i get the...
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jun 13, 2009 | Vivitar ViviCam 3765 Digital Camera
Mar 31, 2009 | Vivitar ViviCam 3765 Digital Camera
No software for vivicam 3765
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dec 24, 2007 | Vivitar ViviCam 3765 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
