How do i remove or disconnect the beeper on my pride mobility go go sport scooter? I have the manual and it's worthless - i need instructions how to do it - i repeat - pride mobility manuals are worthless and i need to know how to access the beeper so i can disconnect or remove it. thank you :)
I'm afraid I don't know, but you are right Pride Mobility manuals are not only worthless but a total disgrace. Company 'Advice' on their user's blog is worse! It runs to "Have you tried reaching out to your provider?" And telling you that fuses that do exist (under the floor hatch) don't exist. It is time that Pride Mobility were taken to task.
SOURCE: instruction manual for celebrity pride 3 wheel mobility scooter
I can send you the manual (PDF) if you send me your email address. My address is (D*H*u*d*s*o*n at GMail dot com), you need to take the stars out and put the @ symbol in and the .com to make it usable.
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
SOURCE: Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Testimonial: "Thanks so much for the help. The seat did come off in the end but with difficulty. Batteries now changed OK. Thanks again. "
SOURCE: Where can i find an
I have downloaded a service manual for your scooter on this site.
You can e-mail me and I can send you a copy.
[email protected]
SOURCE: I have a 2003 Model
Stan if you e-mail me @ [email protected] I'll send you a PDF copyy a service manual
Hopes this helps you
