Question about Nova Development Photo Explosion Deluxe for PC
Load MPEG Vio Driver Error
Ulead.dat\PE.ini is the error. Bought new computer with Windows Vista and this new software that says it is Vista compatible. Any help?
  • 13 more comments
  • pixiemajic Nov 22, 2007
    i am having the same issue for software photo explosion--any help would be appreciated!
  • Anonymous Dec 08, 2007
    I just purchased the software and have a new Vista computer and I am experiencing the same problem. Does anyone have a solution?
  • depper Dec 27, 2007
    get load mpeg vio driver error after installation
  • J C Klein Dec 28, 2007
    I just got a new Dell with Vist and have the same issue when I try to open the Photo Explorer; uninstaked and reinstalled and got the same thing. ANy help here would be greatly appreciated.
  • piamemow Jan 22, 2008
    bought photo explosion. have the same load mpeg vio driver error problem cant get help from nova. I have vista to
  • pcmdoc Feb 12, 2008
    I have Vista Home Premium, and just bought a new copy of Photo Explosion 8.6, when I try to run Photo explosion, I get the same error. When I try to run Photo explorer it gets a couple of errors, and it won't display the serial number so I can't even register it to get technical support!!
    THis was a clean error free install, and I did reboot it as suggested in the install.
  • Anonymous Mar 31, 2008
    Brand new pc with Vista, I loaded Photo Impact Pro 11, but it will not open,
    downloaded patch, talked with Vova tech, it still does not work. Help please.
  • Diuane Apr 13, 2008
    New PC with Vista....Old version of Photo Explosion would not work, so I bought the "new" version that would work with Vista.....Yeah, Right!
    When I open Photo Explosion, I get the error message "Load MPEGVIO driver error." I went to Nova's website and downloaded instructions on how to fix it, They tell me to go to Ulead Photo Express folder and 2X click on 6.0 folder, then right click on pe or pe-ini.......Well I can't find any of those. VERY FRUSTRATING!!!
  • jazzyet Jun 04, 2008
    photo explosion/deluxe 3.0\ulead.dat\pe.ini, reinstalled program and still get this message
  • Anonymous Jul 14, 2008
    MPEG ulead error
  • craftyjw Jul 24, 2008
    Photo Explosion will not completely install due to a problem that there is a MPEG vio Driver Error. I have tried several different ways to correct this problem. Need assistance with this.
  • drovecrazy Nov 08, 2008
  • bevnee Dec 27, 2008
    just bought Photo Explosion, installed ok but when I click on the icon to run it, an error comes up "load MPEG vio Driver error" C;\Program Files\Nova Development\Photo Explosion 3.0\Ulead.Dat\PE.ini
  • The 440 Jan 04, 2009
    I now have the same problem since I installed it on a new computer with Wndows Vista.I never had a problem with Win XP.
  • Darkseid Jan 11, 2009
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: Ipe.exe
    Application Version:
    Application Timestamp: 46008f3f
    Fault Module Name: uExifLib.dll
    Fault Module Version:
    Fault Module Timestamp: 446d3dd8
    Exception Code: c0000005
    Exception Offset: 00008a62
    OS Version: 6.0.6001.
    Locale ID: 1033
    Additional Information 1: 9f49
    Additional Information 2: 6c8bcefc48cbfa2d1815d73cdcf79c06
    Additional Information 3: 2360
    Additional Information 4: 0188a5fed43f531393c36dbff0c70e81
    Read our privacy statement:
When i click on phot explosion i get mpeg vio driver. I now have vista and need to know is there a patch to fix this? thanks anything helps tina
Posted on Sep 26, 2008
Where is this NOVA patch..and why are they still selling it?
Posted on Sep 29, 2009
Downloaded patch from Nova Development worked for me too. Took a while to download tho'---even with a high speed ethernet connection.
Posted on Jan 10, 2008
There is a solution on under technical support.faq; however, the steps it provide are for XP and not VISTA. I called the tech support number and the tech person walked me through the steps to correct on VISTA. It fixed the problem but the program still wouldn't load; then I went to run; did a msconfig and ran a diagnostic start up to turn the start up menu items off; when I clicked the photo explorer it worked so this means there is something in the start up menu preventing it from running. NOw I have to figure out what that is. If anyone can help me with this we may be able to solve this problem. My computer isn't even a week old.
Posted on Dec 31, 2007
Nope but here we are in 2010 and Walmart are selling a cheap printer with this program as part of the package so I am sure there will be lots more post, because I now have the same problem. Oh yey...
Posted on Apr 28, 2010
If you are having a problem with Photo Explosion on any version, go to:   <--- File a complaint against them, and it will appear on all "search engines".."Fix Ya" should be "free" but unfortunately there goes the "almighty dollar" again.. :o(
Posted on Feb 05, 2010
Same error problem. But I have had Photo Explosion 2.0 for a couple years and ran fine. Now,even though it is there in my computer, under program files shows it's not there-so...I can't uninstall it!
I am going to try the patch.
Posted on Aug 09, 2008
Try installing the patch from the suppport website. It worked for me.
Posted on Jan 06, 2008
I installed a patch available at the support website and the problem has gone away
I installed photo explosion on my install but when i try to use it it pops up a error load mpeg driver sent me a patch for it to work it did work 2 times and throwed the error up again now it will not work .look i gave $49.99 pluse tax for this package and it will not work wouldn,t that make you mad. i need some help or my money back do something
thank you
upset customer
Posted on Dec 11, 2009
Hello load mpeg driver vio not found
First i have to confirm you MPEG in file format of video clip or movie file, you have to install mpeg player, if try to play in "windows media player" you get no luck. so that one you i suggest to you download the VLC player, this is a multiple player to play the different type of music and video format.
1) Download the VLC player
2) Easy installation in all Windows version.
God Luck
Sep 03, 2011 | Ulead DVD MovieFactory 4 for PC
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
Load mpeg vio drive error is the error when I
go to the manufacturers website and find the drivers there
Feb 15, 2010 | Nova Development Photo Explosion Deluxe...
Having problem with Photo Explosion on Windows 7. Get this error Load MPEG vio Driver Error "ulead.datPE.ini
A way to fix this error which is a font problem is to take the PE.ini from ProgramData\Ulead Systems\Ulead Photo Express\6.0 and stick it in the ulead.dat file in the Program Files (x86) if you have a 64 bit system and then find the u32Comm file in the program files (x86) and change the font to a font where it will not say that error again, I have done this in Windows Vista before and it worked, I also done it in Windows 7 and that also worked allthough right now I can't remember what font so you'll have to trial and error the fonts and maybe the sizes etc. but it's mainly a font error within Photo Explosion Deluxe, 1 problem I'm having is Photo Explosion Deluxe 3.0 loads on one desktop and loads fine newly created desktops but it doesn't load on others. I figure it was made by cheap software creators.
Nov 29, 2009 | Nova Development Photo Explosion Deluxe...
Error message "load mpeg vio driver error" when I try to start program using Vista. One of the solutions was to install a driver robot program, but is it a legal program or one of those that scan all the...
Some file is missing so that the messege appears. To repair the problem repair or uninstall the software. it will work . If it does not work then you have problem in either windows or installation file.
Nov 18, 2009 | Nova Development Photo Explosion Deluxe...
C:Program Files/Nova Development/Photo Explosion
try uninstalling the software,disconnect from the net,and then disable your anti-virus.then reinstall the software. This sounds like you might have a corrupted install
Oct 26, 2009 | Lexmark All-in-One Printer with PictBridge
Error message: is " ulead.dat\PE.ini "
the only solution is to contact directly the support of that software cause they are more familiar with that application. just an advise, if you encountered a problem with a certain product, directly contact the support cause they are more familiar with their product.
May 25, 2009 | Nova Development Photo Explosion Deluxe...
Error on Photo doesn't work.
Have you tried to reinstall the program after uninstalling it? This may fix-Ya
Apr 13, 2009 | Nova Development Photo Explosion Deluxe...
To resolve this Ulead has com up with a patch
Select the site & Download the patch from here
Good Luck.
Live, Love, Laugh.
Dec 25, 2007 | Ulead Videostudio 8 for PC
Nova Development Photo Explosion Deluxe for PC Logo
4,901 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
