How to remove the power steering pressure hose
You have to discon the battery cable before you start. Remove the coolant expansion tank. Remove the drivebelt and alternator if you have an OHV V6. Raise the vehicle on jack stands. Place a drain pan below the pump. From below, remove the splash shield and discon any brackets or ties that hold the hose to the body. After draining, you may have to replace the pwr steering fluid filter, located in the fluid line, then replace the fluid. A crows-foot wrench may be necessary to remove some hose fittings. This is a job for a mechanic with a power lift to be honest. Whatever you do, be careful not to contaminate the power steering fluid. Bleed the system after replacing the hose. The pressure hose is held in place by threads and not a clamp as the other hose has. Get yourself the Haynes repair manual 36075 '96 thru 2005 Ford Taurus & Merc Sable. It has a detailed step by step description of this procedure. Good Luck
SOURCE: Looking for shift solenoid on 1999 Mercury Sable
I believe these are internal you must drop the trans. pan down to access it.
SOURCE: power steering leak on passengers side of 1999 mercury sable.
If it "RED" in color, like p/s fluid, and coming from the BOOT, then its your p/s rack assembly.The unit has to be replaced and alignment reset. ..also check the HOSES they are prone to leak also...hope this helped..GL
SOURCE: where is the Power steering pressure switch
it is located in the p/s line at the steering rack where the steering shaft is located
SOURCE: Where to find power steering
It is difficult ot find it online to buiy the part but the switch alone itself will cost around $45. Pump some $90 and hose and other thing it will round up to $300 ... So i think he has given an nominal rate...
Testimonial: "Thanks for the quick response. Dealer says that is the cost for the part alone, to provide to my mechanic."
SOURCE: no diagram for 1999 mercury sable for serpentine
Click on the following free direct Link.
It has the correct Belt Diagrams for your 1999 Mercury Sable 3.0L V6.
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1999/make/mercury/model/sable/1999_mercury_sable_drive_belt_routing_diagram.htm
