First i soldered dry joints and I check some H & V section capacitors with my home made ESR tester,all fine. One i suspect was R544 resistor is over heated and markings are disappeard, and i don't know the correct value.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to screen are given with illustrations. You can get an idea about the fault to an extent.
Testimonial: "Hi, Knight I try the link but can't find the TC-25P22R circuit diagram or troubleshooting tips, thanks."
SOURCE: help on value of surge R801 Panasonic CT27SX11E Please
Check this out. http://www.pasc.panasonic.com/Epartr/PartsList.asp
SOURCE: TV failure
I would say it is in the power supply circuit. check the 145 v line I do not suspect the problem in the video section.The 145 volts feed to the flyback.
SOURCE: Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
SOURCE: My TV panasonic CT32G23W shut off while it is on. It back ON if I
A good eye could help you to know if a solder join is defective, get ahead lookin for it first. But the technical answer to know if the power supply shuts off because an over current or over voltage protection, is always a way to walk thrue. what is sure, it is, if you continue hitting the tv maybe is going to be broken totally.
