Question about Frigidaire GLTF2940ES Front Load Washer
Directions on stacking dryer on washer
In need of directions on how to stack the Frigidaire dryer on washer. Model GLTF2940ES (washer) Model GLEQ2152ES (dryer).
  • 4 more comments
  • Anonymous Jan 14, 2009
    we have the stacking kit parts but can't find the instructions for installation. the washer and dryer are Maytag. Can you provide basic instructions?
  • Anonymous Mar 14, 2014
    Dryer T7744C stacked on top of W1712 washing machine. Need instruction on how to prepare for move and how to stack after move to new location
  • Anonymous Mar 16, 2014
    what year is our kenmore washer dryer stacked mod 11088732792
  • Anonymous Mar 18, 2014
    What would be the reason for this washer stack-mate to overflow 40-50gals of water onto w/w carpeting and flooding down into the ceiling from a second floor?
  • Anonymous Mar 23, 2014
    can I stack a maytag dryer on top of a bosch washer?
  • Anonymous Mar 24, 2014
    Do i go in from the back or from the top of the washer
Get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
Stacking dryer
the 2 plastic pieces 1 goes on front 1 on back,,place the one that has open for dryer legs on back,,,and the one in front does not have openings you must pick up dryer to get font on ,,slide back first than pick up front
Dec 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Dec 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Nov 24, 2007 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
916 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
