Hi, i am having the same problem with a Blu smartphone do you figured out how to fix it?
Okay, here's what you do:
Once the phone is turned on, remove the back cover and remove the battery. DO NOT TURN OFF THE PHONE (Very important), just remove the battery, Leave the battery out for 5 minutes, then put it back in.
Let me know what happened after.....
The phone does not have a removable back. We need a master unlock code or the preset unlock code. Also, it will only accept digits as a number only keypad pops up to enter the code. I must have accidentally pressed to check the guest lock box when scrolling down on the security menu. Blu is very difficultt o contact for customers service. Please help!
SOURCE: What is the default password for micromax x211
The default password of micromax
x211 is-----1122
SOURCE: Nokia 6233, mobile asking security code to set "phone memory" for saving contacts.
It's a 5 digit number.
You should have a:
PIN,
SECURITY,
PUK, numbers
PIN locks your SIM card.
SECURITY locks your phone.
PUK unblock everything.
SOURCE: I have S3653 mobile. I
Welcome to Fixya
Default phone lock code for samsung if it didn't changed before then it is 00000000 (eight zero's)
Enter It, Your phone will be switched on
If you found this helpful for you then your Rating as Four Thumbs which are given below this solution will appreciate me
Thanks
