how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get
a lens cleaner and use it to clean the lens, but if the lens still does
the same thing even after using the lens cleaner, then it means you
would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Likely your lens is just dirty. Ars put up a great tutorial for this repair (I advise you not to play with the lens-adjustment section unless a mere cleaning doesn't work) here:
If it's a Slim, skip the "opening" stuff and just follow the instructions for cleaning the lens, it's already exposed when you open the top of the unit.
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement.
Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
