Using remote control
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: TV CODES
tengo un control remoto universal GH RC84912 nesecito los codigos l para un televisor philips me lo pueden enviar a mi correo [email protected] de ante mano gracias
SOURCE: I have an RCA remote control model rc27a and an
There are remote codes that will work the basics, Although try another code to get the rest of the functions
http://www.xdiv.com/remotes/
http://www.tvcodes.com/index.html
SOURCE: remote code orion tv/vcr # tvcr0950bw
I had a bugger of a time trying to solve this exact same problem. I went through 3 universal remotes before I found a winner. Using the Jensen Surf Series SC-340 I managed to figure out the code for the vcr to be 687. This is not listed in the manual that I looked up for the remote, probably because the remote was made in 1997 while the tv/vcr is 1998. After trying the ~30 codes in the manual I set the remote to auto scan for the code. After 30min scanning for the tv code I switched over to scan for the vcr code. Three minutes later I get the code and that "Oh yeah. Who got this bad boy to work? You did! That's right!" kinda feeling. I hope this helps.
TLDR: I got a Jensen Surf Series SC-340 Universal Remote to work with the tvcr0950bw using the code 687 on the vcr.
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
