Question about Intel Desktop Board D845WN Motherboard
Intel D845WN Desktop Board
I have inspected all connections on all wires, tried new PSU, I suspect a board problem or CPU. The video card is ok; since there is display on the monitor. Any other suggestions please.
Sidlahora
  • Isidro Lahora Nov 14, 2007
    System starts but power off by itself.
  • 85 Answers
What does it NOT do?
Posted on Nov 13, 2007
  • Shawn Bowman
    Shawn Bowman Nov 14, 2007
    What does your monitor show, what point does it turn off?
Download Intel D845WN Motherboard Drivers
go to intel download drivers support type in board then download ok
Oct 23, 2013 | Intel Desktop Board D845WN Motherboard
Intel desktop board d845wn front panel powder led, power switch, hdd led, reset switch connection problem.
Hi, here you can read info and download drivers
for your mainboard:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845wn
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
Sep 20, 2011 | Intel Desktop Board D845WN Motherboard
I haven't driver
here : http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845WN
Mar 05, 2011 | Intel Desktop Board D845WN Motherboard
After installing my Intel D845WN m/board and connecting up the power supply with the ram, AGP card etc., the processor fan on top of the heat sink started running when I switched on the main power supply...
You probably have the case panel connections in the wrong places. Double check the board's manual and the connectors. Most case manufacturers have the connectors printed with their functions.
Oct 14, 2009 | Intel Desktop Board D845WN Motherboard
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
Intel D845Wn Motherboard
possible on first question but debatable to do it as something else could have caused them to blow
check the web for similar boards but I would not get similar I would get the latest one I could afford with CPU and change all drives and card over to it then you have a more up to date computer for minimum cost
Aug 12, 2008 | Intel Desktop Board D845WN Motherboard
133hz sdram problem
Please check this Intel link that shows specifications for memory that can be used in the Intel D845WN motherboard.
http://www.intel.com/support/motherboards/desktop/d845wn/sb/cs-008941.htm#1
When upgrading or increasing memory. The DIMM's should be the same. The Intel D845WN board requires the memory to run at 3.3volt. If the memory you are adding is within the Intel spec's, than switch the two Dimm's. Insert only the new DIMM & check if the system hangs. If it does than it is possible the new memory it either not compatable or is defective. For more information about the D845WN board download the manual for you're Intel board. http://support.intel.com/support/motherboards/desktop/d845wn/sb/cs-008937.htm
Luck!
Mike
May 19, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Cannot power on PSU
If you know for certain that the Power Supply is good. (tried another in there) then you have a bad motherboard. No, the CMOS battery will not keep it from coming on.
Dec 31, 2007 | Intel Desktop Board D845WN Motherboard
Intel Mother Board D845WN
Seems there is a loose wire, loose card, motherboard failure or mis-plugged wire. IS everything in right?
Nov 09, 2007 | Intel Desktop Board D845WN Motherboard
No screen display at all and no short beep for post-intel D845WN board
Try the old memory back in and see if you get the bios screen showing up, if not find the clear cmos jumper either marked JBat 1, clrclk, clrcmos or similar and try again. If neither your old memory or new no longer allows the pc to boot, i would say that the motherboard has been stressed when you have fitted the memory by forcing a flexing in the board and damaging the cmos chip, only replacing the board can resolve the issue if that is the case
Jul 03, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Intel Desktop Board D845WN Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
