Question about SanDisk Sansa e250 MP3 Player
Computer won't recognixe
When I plug it to the USB, my computer says device not recognized. I have another player and I connected it, and it worked. So it is the player, do you have a solution?
Connect it to pc close the window that pops up go to "my computer" find and right click on the device letter and select format (do a full format not a quick) then when finished select safely remove device and unplug usb then shutdown player and reconnect to pc and see what happens. remember to always safely remove device.
Posted on Nov 12, 2007
My sony nwz-s638f is not charging if i put it in the plug how can i make it work?
Please make sure that the Computer is recognizing the Walkman when connected to the USB port.
Make sure that you're using the supplied USB cable for connecting to the Computer.
If you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer.
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not charged by the computer, try a different USB port.
Thanks for using FixYa.
May 05, 2011 | Sony NWZS638F Digital Media Player
Low Battery Mp3 player How do you charge it? Thought it was thru the USSB port on computer with computer on?
Hi dave holte,
It should be through the USB port, I don't think any players nowadays have separate ports for charging. Nevertheless, check if there is any port other than the headphone and the USB, because it never hurts to check. Does the computer recognize the device when you plug the mp3 player into the USB? It might be loose connection as well. Or maybe it is not set to be recognized as an MTP or Plug-and-Play device. Once you have it plugged in, go to My Computer (I'm assuming you are on PC) --> Device Manager and then scan for new hardware changes. Probably then you have to manually install the device and its drivers. But do check for the loose connections. Ask back if it doesn't work.
Mar 25, 2010 | RCA TH1611 MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Usb is not recognizing sansa
try going to "my computer" on your desktop and it should show an unkown device thats plugged into one of your drives
Aug 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
My pc isn't recognixing my mp3
It sounds like you need to install the driver for the mp3 player on that computer.
May 13, 2009 | Dell XPS M1210 Notebook
Usb device not recognized when i plug in my zune
maybe the USB is rusty or also happens to me
May 05, 2009 | Microsoft Zune JS8-00001 Digital Media...
Mp3 player won't sync with media player on vista
Do you have Windows Media Player 11? When you plug your device in and hit sync you should be prompted automatically, to name your device.
Also try:
Plug in the device, press the POWER BUTTON go to MY COMPUTER and double ckick on the Setup.exe icon.
This will install the MP3 Player's software onto the connected computer. At least that's what the manual says.
Feb 24, 2009 | GPX ML648B MP3 Player
No device recognized when connected to computer
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 13, 2008 | RCA OPAL M4001 MP3 Player
Problems with computer connection
There's many reason that explain why a usb device can't be recognized by a computer, such as:
If it use to be recognized & function:
- Try the device on other computer, to check if it is ok.
- Try the computer with other device.
- Some computer virus can damage the function of usb device, if it is, try to clean up your computer and usb device.
- If you ever plug other similar device to the computer, and the device failed to be installed, then the computer will mark all similar device as unknown. Try to reinstall the driver, but remove the unknown mark first (plug the device, right click on my computer, properties, device manager, then find device with question mark or X mark, then uninstall it)
If it has never work with the computer before:
- Try other driver, contact the device vendor, or find in internet
Feb 02, 2008 | Coby MP-C7085 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
