Thick Vertical White Line Through My LCD Monitor!!!
I have a Toshiba Satellite P105-s6024 i had it for a little over a year now.
About 2 months ago i noticed a thin blue vertical line through the scree about 2" from the left side of the screen, after reading some of the answers on this website i knew there was a problem with the screen.
This morning i woke up finding a Thick White Line 1.5" thick at about 3" from the left side of the screen! i was shocked, so the first thing i do is restart my computer hoping its a mess up, but it persists, and it shows as soon as there is power in the LCD... i think its a fatal problem with the LCD but i am wanting to hear otherwise... please let me know if you know otherwise, or if you have any solutions...
Thank you...
The monitor specs are:
-17.0” diagonal widescreen TruBrite™ TFT active-matrix LCD
display at 1440x900 native resolution (WXGA+)
-Intel® Graphics Media Accelerator 950 with 32MB-128MB
dynamically allocated shared graphics memory
  • 2 more comments
  • soudan Nov 12, 2007
    The blue and white lines appear in the picture below.
  • Anonymous Dec 18, 2007
    I have the same size and description verticl line. Except mine is on the right side. Did a new LCD fix it?
  • osully58 Dec 31, 2008
    I have a thick vertical white line on my HP pavilion 8000 laptop.
Wow I repaired a laptop, err actually the same exact model!! Same problem although the thick white line was about 1.5in to the right of where yours is. Anyway it was the screen itself (or my theory is the lcd itself is fine but the circuit board on the back top of the LCD screen is bad) Either way its best to replace the whole LCD. You can find compatible replacement LCD online between $175-$250 a bit less if you buy used.
Posted on May 12, 2008
  • 72 Answers
You can check if it is a screen or not. Connect another screen to your laptop. If you dont have anotherone you can use your friends screen or go to the nerest computer store and test one there. That way you know 100% it is the screen or another thing: video card wireing...
Posted on Nov 12, 2007
My Toshiba P105 has a vertical white stripe on its monitor. Any help is appreciated.
A vertical white stripe means a portion of the lcd has will continue to get worse as time progresses. The ONLY way to fix it is to swap the lcd out with a working one. It isn't a loose connection, etc.
Mar 18, 2011 | Toshiba Satellite P105-S6104 Notebook
Monitor has a vertical line through it
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Dec 29, 2010 | Toshiba Satellite P105-S6024 Notebook
Toshiba Satellite P105-S6024 screen problem
If this is happening once the PC has fully loaded the OS. You then possibly have a bad inverter or bad LCD screen. Try reloading the video driver and see if this helps. If it doesnt then you will have to replace the inverter or LCD screen. A local repair shop should be able to replace these. And I would have them try to replace the inverter first as it is usually cheaper then the screen.
Best of luck and have a Happy and safe 4th of July weekend!
Jul 02, 2010 | Toshiba Satellite P105-S6024 Notebook
My Problem w/ my Toshiba Satellite P105-S9337 model no. PSPAGU - OOJOOV is it has a strip of white line vertical on the screen and it's about 1" thick? is their a way I can fix this problem?
Connect an external monitor to the VGA port on the computer. If that display is correct, then it's probably the LCD screen on your laptop that is damaged.
Find a computer-store. They may have "pre-owned" LCD screens the same size, for about $100.
A "brand-new" LCD screen is at least $200.
Replacing the LCD screen is *NOT* something that *YOU* can fix, unless you're a qualified technician.
Jun 15, 2010 | Toshiba Satellite 1105 Series 14.1" Flat...
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
No sound
Your speaker wires may be disconnected from the sound board. See diagram 15 at . It's pretty easy to peak into the case when the front case screws are removed.
Dec 18, 2008 | Toshiba Satellite P105-S6024 Notebook
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Computers & Internet Logo
6,007 people viewed this question
David Payne
David Payne
