Internet was working this AM but stopped. Every other device in the house is working
Hi Mike,
There is a possibility that the Wi-Fi may not have been enabled so please let me know the system model so that I can let you know what needs to be done. You may also send me the system service tag so that if Wi-Fi is already enabled then I can check and provide the right Wi-Fi driver.
Thanks & Regards,
Kiran K
#IworkforDell
Hi man, one of my clients had a same problem . the best way is by reinstalling a wifi driver. do this by going to control panel-hardware and sound,then click device manager. under network adapters uninstalling all the drivers. next restart computer.
if this dosent work follow by downloading a diffrent wifi driver on another internet enabled laptop or phone and transfere to your pc and install. thanks
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
