Question about Akai LCT3201AD 32 in. LCD Television
Mono Vs Stereo
AKAI LCT3201AD. This TV constantly goes back and forth from Mono to Mono Stereo. I can be watching the same channel, same show, and every 3 or 4 mins its goes to Mono Stero for a sec (sounds like crap), then Bacxk to Mono. I have never had this problem with any other TV. How can i fix this?
Re: Mono Vs Stereo
Here is what I found out. I had this same problem. I have cable TV and the signal coming into my house was not very strong. They 'boosted' the signal and this problem stopped. Along the way, they tested that the cable line had been passing through a splitter, so that to the house the signal was good, but by the time it passed all of the splitters, the signal was not strong enough. Now all is well and the problem does not happen anymore.
Posted on Aug 12, 2008
0 characters
3 Points
Flashing problem
Hi, it seems your TV requires technical service, it's seems a internal power supply issue but it should be checked. You can also check if the ventilation holes are not obstructed or if it has correct ventilation to avoid overheating.
Nov 02, 2015 | Akai LCT3201AD 32 in. LCD Television
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a 37" combo TV/DVD unit. It's been doing this for about 6 months. Wrote to tech support from their website. Got nothing but an automatic response. When I called them, they automatically tell you the part you need is not available. It is a law that a part be available for 7 years. I have filed a complaint with the Bureau of Electronic and Appliance Repair (BEAR) against them. I need a new LCD control panel. Others have had success getting the parts they needed by going this route. Try it. Maybe they'll stop scamming us consumers. They get your TV back, fix it and resell it as reconditioned.
Aug 15, 2008 | Akai LCT3201AD 32 in. LCD Television
Panel buttons and remote controls are both erratic
Problem seems in panel board having bad switches. You probably need to replace the (control) panle board. Check out this Weblink having info for Akai TV parts.
Jul 21, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai model lct2721ad. tv.
Mine does this all the time. It appears to be a factory flaw. The only way around it is to set the channel you are watching to "MONO" and the crackling sound will disappear.
May 11, 2008 | Akai LCT2721AD 27 in. LCD Television
Volumne on Akai LCT3285TA
Often a signal might experience a super-quick "drop" in signal strength, and the display is automatically adjusting the now weaker audio signal to "mono" (temporary, as for best quality). But the dropout is usually so brief you will then see the "stronger" signal restored [full strength], and now the audio is "stereo".
It's like a "bump" or "disturbance" that occasionally affects the cable/satellite/OTA (antennae) signal being fed into the TV, and your display's attempts to compensate for the weaker signal [going to mono, then back to stereo once back to full strength].
Connecting it to your cable directly (bypassing the box) or an antenna would give you a true over-the-air signal, which would be proper MTS and would not give you any more pop ups.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
LCT3201AD tv mode stereo only?
AKAI told me that I needed to get a cable tuning box to fix this.
No other way would work
Nov 04, 2007 | Akai LCT3201TD 32 in. LCD Television
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
542 people viewed this question
Top Akai Flat Panel Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Flat Panel Television Expert? Answer questions, earn points and help others
