Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mirror i had my tv mirror cleaned a year ago but now there are dust fragments on it since we moved and the warranty is out. i cant afford to have it cleaned again but i am very mechanicaly inclined. can you please explain the procedure of cleaning the mirror on my wd-62327 mitsubishi dlp tv!thanks in advanceshawn wingo
  • shawn_wingo Nov 26, 2007
    answer had nothing to do with the actual question
    Explain the procedure of accessing and cleaning the mirror
  • trek-rider Dec 21, 2007
    I would also like to attempt to clean the mirror assembly but I see the solution was given a bad review. Has anyone actually attempted this and if so did it work?
  • 56 Answers
There is black insulating foam that surrounds the projector and it may be displaced to one side.This leaves about an 1 inch opening around the projector lens and that could be the source of the problem,dust being blown into the compartment with the mirrors.
Cleaned the mirrors really well and used double stick tape to reattach the foam to the plastic frame and this will closed off the opening that maybe letting the dust into the mirrored area of the TV.
Posted on Nov 12, 2007
  • Tony Clayton
    Tony Clayton Nov 26, 2007
    remove speaker grille
    remove 2 screws that hold bottom corners of screen
    remove 2 screws that hold the plastic bottom portion that the controls are attached to remove 4 screws that hold the panel in the middle of the tv under the screen-unplug the connector.
    remove the screws all along the outer side and top edges if need be take care to slowly pry the screen off all around
    lift screen up and out you'll see a big hollow space, and the mirror is exposed in the middle on the bottom.
    take a vacuum with my dust attachment and get the big dust balls out first It's a good time to vacuumed all around the outside and edges with the duster attachment.
    used glass cleaner with lint free rag to wipe the mirror down use small strips of duct tape to cover up the hole where the foam had came unglued next to the lens.
    I hope these are the instruction you are looking for.
Need to Clean The lense
If this is a projection TV (DLP or LCD), dust could be on the lens or the mirror assembly. Moving a set can dislodge dust and dirt that's accumulated inside and deposit it onto the lense or mirror. A worst-case scenario would be dust on the LCD chips. Unless you're experienced and/or comfortable opening up the set, I'd recommend contacting a local TV serviceman.
Oct 02, 2012 | JVC Televison & Video
Sound stopped working
if the tv is less than a year then this should still be under warranty. contact the vendor for warranty claims.
Aug 22, 2012 | Viore 42" 1080p LED LCD HDTV
How do I get in there safely to clean the mirror?? what do i unscrew first etc.. it still working just fine but the color is going after 15 years and i need to clean the inside.
I would not recommend you to touch the mirror. It is hanged sort of reflection surface facing down so it is not real dust collector. You can clean lenses of your CRT tubes (red, green and blue) to improve your picture. Just remove rear cover taking out black and golden screws and you will see dusty lenses right away in the middle of the TV. Use DRY "Bounty" paper towels to remove dust from lenses, don't wet it with any solutions or it will leave film on optics. Just in circular motion move dust to the black plastic edges of lenses. Don't worry about some specs of dust that inevitable will be left behind - they will not affect image at all like thick layer of dust do.
Dec 01, 2010 | Mitsubishi VS-6041 60" Rear Projection...
Red light
Make sure you have atleat 8" of space behind the set. Also if you have any type of filter or a fine mesh screen over the lamp cage you should take it out and clean of the dust once in a while. Lack of air flow will shorten the lamps life. Also turning it off and on repeatedly. If you turn the TV on in the morrning and it does not go off till night then all you will get is a year out of it.
Mar 11, 2010 | HP Md5880n 58 in. HDTV
Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
May 28, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Lg turns off by itself
Could be a failing power supply
Jan 25, 2018 | LG 37LC7D 37 in. LCD HDTV
Spots on tv picture
A friend of mine had the same problem. It is dust on the mirrors, but I recommend you have it professionally cleaned. They had theirs done and it fixed the problem
Feb 02, 2008 | Mitsubishi WD62327 TV
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
Epson livingstation 45" tv
I just fixed the problem on my epson 57" living station. The picture is like new. Yo have to clean the dust off of the the 3 lcd lenses. (I'm not sure if thay are actually called lenses)
You can get to these by entering thru the front of the TV. Yes the front. You must remove the screen. There are A LOT of screws. This screen housing covers the entire front of the tv. and you have to remove the back panel and ALL the screws on the back of the tv to get it off. The only electronics that have to be disconnected are the Speakers and the front control panel. They both have snap connectors. After you remove the entire front panel which houses the screen and expose the inside mirror you will see more screws. You must remove those as well to remove the mirror housing. DO NOT REMOVE THE MIRROR FROM THE HOUSING. Note that there is a peg that is next to a screw in thre front of the mirror housing thst you must pull the plastic housing out in that area to release it.After you remove the mirror housing you will see the 3 LCD panels or lenses. YOU DO NOT HAVE TO REMOVE ANY ELECTRONICS OR SCREWS AT THIS POINT. Use a can of compessed air to spray the dust out of this area. I used a vacume to catch the dust as it flew out in the air. Try to hold the can as upright as possible.Keep hitting it with the air until no more dust comes out. Put the tv back together. As you open up the tv you will see dust everywhere. I took the oppurtunity to clean as much as I could. The Mirror though was clean an I was afraid to touch it.
I am a Construction Salesman yet fairly handy. I have no electricle experience. This took me 2 1/2 hrs. I spent the first 45 min. trying to get to the lcd panels from the back of the tv. Don't waste your time. You can't.
Mar 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Rear projection toshiba picture and color too dark
Clean the GLASS mirror with glass cleaner, clean the lenses with a soft DRY T-Shirt type material cloth, clean the screens with same DRY Cloth very gently. The heat created by the tv goes up and out depositing dust/dirt/soot/anything airborn on the optical path.
Mar 03, 2007 | Toshiba 46H84 46" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
863 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
