PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
Colin Graham PT Posted on Dec 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i move photo's from a external card to a internal memory on a digital photo frame
  • Harrie Dec 26, 2014
    Hi Colin Graham PT, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What frame? brand and model please.
Harrie
Level 3:
Top Expert:
  • Master 6,746 Answers
  • Posted on Dec 26, 2014
 Harrie
Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285563
Points
83153
Stu, This is a good answer, but not for this question. The question is not about a computer, but a digital photo frame.
That is why I asked for the brand and model of the frame.
  • Stu Morris K Dec 31, 2014
    the question itself does not require the information you ask for
Stu Morris K
Level 2:
Scholar:
  • Expert 178 Answers
Stu Morris K
Expert
Level 2:
Scholar:
Answers
178
Questions
Helped
36811
Points
376
If you have an external card reader, attach it to your computer by using a USB cable. Your computer should instantly recognize the card.
How do i move photo's from a external card - 91514.image3.jpgHow do i move photo's from a external card - enlarge.gifmg src="/uploads/images/enlarge.gif" alt="enlarge.gif" class="h_mi" /> Enlarge
Insert a memory card into the card reader. Again, your computer will notice the card reader and make the files (photos) available. 91516.image5.jpg enlarge.gif Enlarge
Open your computer's main system folder, then open the card reader's drive. This figure shows a Windows computer system folder, including a card reader. 4
Open the folder into which you want to copy the image files. You can also simply drag the files to your computer's desktop. 5
Drag and drop the image files in the reader's folder to your computer's hard drive. You can place the files either in the folder you opened or on the desktop.
Sony DPF-D820 8-Inch Digital Photo Frame. Can you export pictures from DPF 8 inch internal memory to memory stick or computer please?
Question edited for a lot more clarity.
Question moved from Cameras.
Yes, you connect it to a computer
https://www.google.com/search?q=DPF+8+inch+internal+memory
Manual
Manuals for DPF-D820 - Sony Canada
https://www.sony.ca > electronics > support > manuals
Find instruction manuals and brochures for DPF-D820. ... [PDF] SD Memory Card Compatibility Information for Digital Photo Frames and Printers(150.5 ...
6helpful
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
How, if possible, do I move photos from internal memory to external? As I don't have a ubs cable to put the internal photos on my computer.
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
How do you download pictures from phone to digital frame
Most digital frames require a memory card to display photos. The first step is to download your photos from your phone to your computer. Then you need to put the memory card you get for your photo frame into the computer if it has a built in card reader or into an external usb card reader. Next open the file that has the photos you want, and open my computer and select the memory card folder. Select the images you want and press control and c to copy them, click on the memory card folder and press control and v to paste them. Then remove the card and put it in the photo frame.
2helpful
Screen says internal memory is full. how do you clear the internal memory
Hi there internal memory means inbuilt memory. When you click the snap all photos are save in your camera internal memory. I hope you use external memory card. Go in settings and select the memory card( external) for further snaps. Then the message did not come again until full the memory card. And if you want to clear the internal memory card then connect your camera with your PC then copy the all photos from the camera & paste in computer. After that go inside the internal memory of camera via computer & delete them. Then your camera in build memory card will empty. I hope you understand . If you have any question then ask me. Thanks & waiting for your feedback.
2helpful
2answers
How do we move the photos to the memory card in the camera?
Get out your manual and read the chapter about file transfers. It should be fairly simple to move the files from internal memory to external memory.
4helpful
5answers
Not enough Memory, LG Renoir camera
From the settings menu, choose phone settings, then Memory Manager.then handset common memory. Chances are, this will nearly all be used up. Move any pictures, video, music etc from the internal memory to the external memory card using the My Stuff application, then move to external memory. This should solve the problem & any new photos will be stored on the external card. When theinternal memory gets full, the Renoir does funny things!!
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Moving photos from pc to Elura 65 camcorder memory card
You can buy both internal and external USB card readers that can read just about any card you can think of in a package about 3" square. They are not expensive either.
Your local PC retailer will (read should) have these in stock.
Hope that helps
Trutech digital photo frame
Most digital photo frames do not have internal memory and require external media to be plugged in permanently. Only the expensive ones have there own memory and usually not a lot.
Get an SD card and move your photos to it, that way you won't need to have the USB drive sticking out of the frame. That's if the frame has an SD slot.
Top PANDIGITAL Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
