Question about Samsung PCN5425R 54" Rear Projection Television
Blurry picture Our tv just all of a sudden started showing a very blurry picture. If searching for something to watch, the letters on the menu are very hard to read due to the blurriness. Also - when trying to do the perfect focus, it doesn't work anymore. Any idea what this is and what the cost may be?
You probably have a bad convergance board you can get one at but if the color is realy out of wack you will need the board it is very easy to install even for a novice unplug the set take off the lower back hte board is on the upper right only one screw and a couple of plugs but first try to adjust the lens have someone watch and loosen the wing nuts and turn the lene,s slowly one at a time i started with the red one you need to have the set on when you do this i replaced the board first works great now
Posted on Dec 20, 2007
My tv overall is blurry, but when I click menu to mess with the settings, only the picture of what I'm watching, and the highlighted word is blurry, but everything else is clear, video games and movies n...
Some of your electronics parts were worn out. Like capacitors may have leaks that need to be replace
as use stated that the word focus were very clear it means that your tube is still okay. or you adjust the focus knob on the compartment. To tune in the 3 colors.
Jan 01, 2011 | Toshiba 57H82 57" Rear Projection...
Blurry screen
I have researched your set. There isn't a date of production that is available so your guesstimate of 11 years old is about where I would place it.
For your specific problem (which is common among old style projection TVs) it's usually the three picture tube or "guns" are showing their age. If it has slowly become more blurry then that is the case. If it has suddenly become blurry then there may be a fixable defect. Judging by it's age I would suspect that your are up for replacing all three tubes in your set. My recommendation is DON'T DO IT. You will be much better off purchasing a newer and preferably flat screen TV. All projection TVs with picture tubes in them typically last between 10,000 and 20,000 hours of operation. At 11 years your set is in that range if you watch an average amount of TV. Enjoy looking for a new set and pick out something that tickles your fancy. Sets have improved vastly with the thin screen technology.
Jun 23, 2010 | Philips 60P8241 60" Rear Projection...
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
Dim and blurry
try adjusting the focus control located on the flyback of the tv. good luck
Jan 31, 2007 | GE 32GT740 32" TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
