Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
thats cos ur machine is set for a dif paper size, in the tray , try it from the bye pass tray in the side but make sure select the correct size on the screen for the tray
On my HP PHotosmart C7280 All in one:
Message appears on Unit.... Ink system has failed Unable to...
(More)
Message appears on Unit.... Ink system has failed Unable to recieve faxes or print.
I replaced all ink cartridges and did a reset... Still the same
Re: PIXMA MX 310 I am not able to install the toner cartridge. They are not sliding into...
(More)
Re: PIXMA MX 310 I am not able to install the toner cartridge. They are not sliding into position
I have a faded vertical section when I print on my Workio DP1810 Copier. I have changed the toner so...
(More)
I have a faded vertical section when I print on my Workio DP1810 Copier. I have changed the toner so it is not that. I wonder if anyone would know the cause?
